11-16-2016, 08:03 | #1 (permalink) |
Insane Poster Join Date: May 2012 Location: USA
Member: 1754897 Status: Offline Sonork: 100.1622738 Thanks Meter: 5 | How to Make eMMC Pro Read at 4 Bit Bus? |
11-19-2016, 07:20 | #3 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Quote:
Sent from my SM-G925F using Tapatalk | |
11-19-2016, 12:09 | #4 (permalink) | |
No Life Poster Join Date: Mar 2016
Member: 2547620 Status: Offline Thanks Meter: 3,431 | Quote:
REV1 - and new one do not have much difference 4 bits yes , if your box is new REV is about 90mm in size. Functions everything same no difference Best regards F4T0N | |
11-21-2016, 17:06 | #5 (permalink) | |
Member: 1754897 Status: Offline Sonork: 100.1622738 Thanks Meter: 5 | Quote:
I was unable to find any information on-line that mentions version 1 of eMMC Pro does not support 4 bit. If it does turn out that I do have a version 1 eMMC Pro box, can I trade this version 1 box in for a version 2 box that supports 4 bit bus? J2 | |
The Following User Says Thank You to Jacques2 For This Useful Post: |
11-22-2016, 17:40 | #7 (permalink) |
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Can you please publish here the pics of the different rev boards so customers can verify with version they have? Sent from my SM-G925F using Tapatalk |
11-23-2016, 11:51 | #8 (permalink) | |
First Design was based on Prototype and our prototype had a SD Card Slot inside and that card slot had a lot of space wasted , once we removed that space we made it efficient hardware and a lot smaller , So only difference 90mm case and taller case . Both hardware works same nothing different , i will post some pictures later Best Regards F4T0N | |
The Following User Says Thank You to FAT-ON For This Useful Post: |
