03-10-2017, 08:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | SM-530H emmc connect successfully Code: www.emmc-pro.com eMMC Pro - eMMC Programmer Version V1.08 CMD_INIT failed. FIRMWARE(0x00000000) version:0000000000000000 SN:0000000000000000 CID:0x42D21202 0x4B13B01C 0x314A3935 0xFE014E50 Manufacturer ID:0xFE Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4E Product name:0x50314A39354B (P1J95K) Product revision:0x13 Product serial number:0xB01C42D2 Manufacturing date:0x12 CRC7 checksum:0x02 CSD:0x92400070 0xFFFFFFEF 0x0F5913FF 0xD06E0132 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x6E Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:1 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:4 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):0 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x38 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x10 HC_ERASE_GRP_SIZE[224]:0x10 ERASE_TIMEOUT_MULT[223]:0x01 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x17 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x06 PARTITION_CONFIG[179]:0x00 BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x10 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x00 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0001D2 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01 NATIVE_SECTOR_SIZE[63]:0x00 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x00 Basic Information: Extended CSD revision: Revision 1.6 (eMMC v4.5) User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 2048KB RPMB Size: 2048KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Writing Done !! full dump write done, just in 2 sec, but phone cant getting boot... |
03-10-2017, 08:55 | #3 (permalink) |
No Life Poster Join Date: Mar 2016
Member: 2547620 Status: Offline Thanks Meter: 3,431 | Hi Bro There seems to be succesful connection but there is some trouble probably with VCC or VCCQ or being short because I can see CMD_INIT failed in your log this might be related to hardware problem in phone or might be something with connection You can try to check again ( phone hardware and connection ) Best regards F4T0N |
03-11-2017, 08:55 | #4 (permalink) |
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | i cheaked each N every connection is ok,i mean NO SHORT with VCC or VCCQ. i also tryed with repair pack,but i m getting error in mbr.bin, but when i write full dump in B1 area, here is full dump write successful without any error but phone cant wake up... https://s28.postimg.org/ordk7ts6l/image.jpg https://s11.postimg.org/u4w7xfqxf/image.jpg |
03-12-2017, 08:39 | #5 (permalink) |
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | FAT-ON bro waiting 4 yur reply.. |
The Following User Says Thank You to vickyjadhav6161 For This Useful Post: |
03-12-2017, 12:29 | #6 (permalink) | |
Member: 2547620 Status: Offline Thanks Meter: 3,431 | Quote:
I will check repair file content tomorrow in the office I will update for you I have enough information with-in thisntopic Best regards F4T0N | |
