07-22-2017, 07:57 | #46 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
1.disable windows auto upodate 2.disable firewall 3.disable antivirous 4.use windows 7 pc if still fail come whatsapp =- +8801911954639 | |
07-24-2017, 11:22 | #47 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | After unlock with lumia unlocker now phone dosent connect with any flasher like ATF, Best, Recovery tool.Whats to do?I think driver is overhidden now but how to enable it?I did uninstall APP driver from software but still dosent work. |
07-25-2017, 09:59 | #48 (permalink) | |
you need contact support in whatsapp | |
08-15-2017, 17:36 | #49 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | i alredy downloaded from some supports few eno files, rename and put in correct folders but nothign happen when press again unlock/download. why should i do? |
The Following 2 Users Say Thank You to Boshko_Alfa For This Useful Post: |
08-24-2017, 01:13 | #51 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1691127 Status: Offline Thanks Meter: 5 | hi friend, please, help me i cant unlock lumia 620 log: Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Loading device info (Client Version 4.3). Done! ***Device Info Model: Lumia 640 LTE (RM-1073) Sw Version: 02177.00000.15184.36016 Product Code: 059X0B8 IMEI: 3578160604xxxxx NETWORK LOCK: ACTIVE Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. Invalid Authentication Token ***Hints*** 1. Check your Internet connection. 2. Check the authentication token. 3. Check the client app's version. SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. Updating devices list. Done! Connecting to server... Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. Invalid Authentication Token ***Hints*** 1. Check your Internet connection. 2. Check the authentication token. 3. Check the client app's version. Loading device info (Client Version 4.3). Done! ***Device Info Model: Lumia 640 LTE (RM-1073) Sw Version: 02177.00000.15184.36016 Product Code: 059X0B8 IMEI: 3578160604xxxxx NETWORK LOCK: ACTIVE Updating devices list. Done! SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. i reflash file .xml and dont can unlock whatsapp +51987592872 |
08-28-2017, 12:42 | #52 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | ***Device Info Model: Nokia Lumia 520 (RM-914) Sw Version: 3058.50000.1425.0010 Product Code: 059S2W9 IMEI: 359205051310763 NETWORK LOCK: ACTIVE Loading device info (Client Version 4.3). Done! ***Device Info Model: Nokia Lumia 520 (RM-914) Sw Version: 3058.50000.1425.0010 Product Code: 059S2W9 IMEI: 359205051310763 NETWORK LOCK: ACTIVE Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. Unable to connect to the remote server ***Hints*** 1. Check your Internet connection. 2. Check the authentication token. 3. Check the client app's version. SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. how to solve this problem thx |
08-28-2017, 19:21 | #54 (permalink) |
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | all lumia unlock server temporary down pls wait some time |
The Following 2 Users Say Thank You to ..::Gsmideazone::.. For This Useful Post: |
09-06-2017, 15:13 | #56 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 38138 Status: Offline Thanks Meter: 4 | Does the handset need to have a non-network product code? Hello, Not having much luck with trying to unlock a Lumia 640 from EE. The handset is flashed with non-branded software but I do not know how to change the product code to match the firmware. Is this why the software is not unlocking the handset: Updating devices list. Done! Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. No phone found in Test Mode SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. Updating devices list. Done! Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. No phone found in Test Mode SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. Loading device info (Client Version 4.3). Done! ***Device Info Model: Lumia 640 LTE (RM-1072) Sw Version: 02177.00000.15184.36003 Product Code: 059X1Q3 IMEI: 35185807xxxxxxxx NETWORK LOCK: ACTIVE Grateful for any advice Many thanks |
The Following User Says Thank You to soudies For This Useful Post: |
09-12-2017, 14:29 | #58 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Zimbabwe, mutare
Member: 1957238 Status: Offline Thanks Meter: 80 | @@@@@@..::Gsmideazone::.. i have a lumia 1520 rm 937 v02061.00066.14253.4004 imei 35834205145235 its now 4 days trying to set it in testmode for but when finished downloading testmode pack software says download error crc32. i tried several time reflashing the and repeat operation with no luck. with other models i managed to do it in few clicks. please help me cause now i am nowhere, should my money go for nothing since the code can only be used on one device. i bought the credit/authentication code from active unlocker, i tried to contact the active unlocker team but they are to slow to respond . what i just need is the good testmode package for the above device causee i even tried manual download and rename the file but the software stuck at setting testmode untill device reboot due to timeout. your help will be appreciated. |
09-12-2017, 20:25 | #59 (permalink) | |
whatsapp me +8801911954639 | |
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post: |
