Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > Gmunlocker(powered by GSMideazone)
Old 11-17-2017, 16:30   #76 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
use new version all pls
https://www.4shared.com/zip/8Gl53vva...ent_v4501.html
Old 11-18-2017, 19:16   #77 (permalink)
Member: 1202427
Sonork: 100.1604781
Thanks Meter: 27
Hello, I already have that version and while I test the connection with server it always says:
X Testing connection with Unlock Server ... FAIL
Since in every version is the same server with the same port no changes have being introduced and every built I have tested has failed in connecting.
I already disabled the firewall and everything else that might block the software.
What might be the problem?
Best regards.
Old 11-18-2017, 23:05   #78 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
Best regards.
disable windows defender
Old 11-19-2017, 01:43   #79 (permalink)
Member: 1202427
Sonork: 100.1604781
Thanks Meter: 27
Windows Defender was already disabled. I use ESET nod32 Smart Security, it has its own firewall and I also disabled it.
I know the server is there, I just can not reach it on the port the application uses.
I even used a tunneling application, just in case there was some other blockade in place, and nothing.
Any other ideas??
Best regards.
Old 11-19-2017, 08:16   #80 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 174
I have error "Unable to connect to remote server try again"
whats the issue? i try different pc but same
Old 11-19-2017, 13:59   #81 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
Any other ideas??
Best regards.
possible to whatsapp me
will try to check the issue
Old 11-19-2017, 13:59   #82 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
possible to whatsapp me?
Old 11-20-2017, 12:41   #83 (permalink)
Member: 2070850
Thanks Meter: 9
Updating devices list. Done!
Loading device info (Client Version 4.5.0.1). Done!
***Device Info
Model: Lumia 630 (RM-976)
Sw Version: 02040.00019.15235.28006
Product Code: 059V9Q6
IMEI: 357138065xxxxxx
NETWORK LOCK: ACTIVE
PHONE LOCKED
Connecting to server...
Loading device info...
Setting phone to TestMode...
Flashing RAM Image.
Image flashed successfuly, now it will boot.
If takes more than 5 seconds, please reconnect USB.
Connecting to device... Ok
Process completed with ERRORS.
***Wait for reboot to confirm the SIMLock status.[Reasons]
1. ChallengeData is missing in server response
***Hints***
1. Check your Internet connection.
2. If problem persist, contact the admin.
Restarting the phone...
***Device Info
PHONE LOCKED
SIM Unlock Failed
*HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure.
I did sw reflash with LumiarecoveryTool ,the problem remains .... ???
Please if someone can help.
Old 11-20-2017, 15:11   #84 (permalink)
Member: 67805
Thanks Meter: 364
***Device Info
PHONE LOCKED
Flashing RAM Image.
***Hints***
***Device Info
PHONE LOCKED
SIM Unlock Failed
Same problem I have, probably server problem
Strpi se
Old 11-20-2017, 15:14   #85 (permalink)
Member: 2070850
Thanks Meter: 9
Thanks bro.
I meni to proslo kroz glavu ,nisam dugo radio unlock pa reko da pitam znas kakve su musterije
Old 11-20-2017, 15:38   #86 (permalink)
Member: 1202427
Sonork: 100.1604781
Thanks Meter: 27
Sorry for the delay, I was not available for the rest of the weekend. How can I contact you through WhatsApp? Can you provide me your contact number in a private message?
BR.
Old 11-21-2017, 09:33   #87 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
BR.
+8801911954639
here whatsapp
Old 12-10-2017, 06:49   #88 (permalink)
lastmile's Avatar
Member: 2482400
Sonork: 100.1677259
Thanks Meter: 115
unlocki error
*** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 ***
Hints
1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed.
2. Need view phone info? Connect it and press 'Get Info' button.
3. Select as many rows as you want and press Ctrl+C to copy it content.
4. More than one phone connected? Connect the device to unlock.
5. Use reload button for rescan the connected devices.
Application info
Version 4.5.0.1
Copyright © 2017
Created by dk
Enjoy it ;-)
***Device Info
Model: Lumia 635 (RM-975)
Sw Version: 02173.00000.15154.50006
Product Code: 059W663
IMEI: 356454063027485
PHONE LOCKED
Flashing RAM Image.
Sending data to server...
1. An error occurred while passing secure commands to terminal
***Hints***
1. There are communication errors between PC and phone. Try restart the unlock process.
***Device Info
PHONE LOCKED
SIM Unlock Failed
plz halp me
Old 12-12-2017, 06:04   #89 (permalink)
Member: 2784830
I need unlock codes for 9 Cricket lumia 640 phones. Please message me your best offer. Thank you
Old 12-12-2017, 19:44   #90 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
whatsapp me
+8801911954639
Page generated in 0.21402 seconds with 9 queries
