11-18-2017, 19:16 | #77 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Cuba
Member: 1202427 Status: Offline Sonork: 100.1604781 Thanks Meter: 27 | Hello, I already have that version and while I test the connection with server it always says: X Testing connection with Unlock Server ... FAIL Since in every version is the same server with the same port no changes have being introduced and every built I have tested has failed in connecting. I already disabled the firewall and everything else that might block the software. What might be the problem? Best regards. |
11-18-2017, 23:05 | #78 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
11-19-2017, 01:43 | #79 (permalink) |
Member: 1202427 Status: Offline Sonork: 100.1604781 Thanks Meter: 27 | Windows Defender was already disabled. I use ESET nod32 Smart Security, it has its own firewall and I also disabled it. I know the server is there, I just can not reach it on the port the application uses. I even used a tunneling application, just in case there was some other blockade in place, and nothing. Any other ideas?? Best regards. |
11-19-2017, 13:59 | #81 (permalink) | |
will try to check the issue | |
11-20-2017, 12:41 | #83 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Gsm World Age: 37
Member: 2070850 Status: Offline Thanks Meter: 9 | Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 630 (RM-976) Sw Version: 02040.00019.15235.28006 Product Code: 059V9Q6 IMEI: 357138065xxxxxx NETWORK LOCK: ACTIVE PHONE LOCKED Connecting to server... Loading device info... Setting phone to TestMode... Updating devices list. Done! Updating devices list. Done! Flashing RAM Image. Image flashed successfuly, now it will boot. If takes more than 5 seconds, please reconnect USB. Updating devices list. Done! Updating devices list. Done! Connecting to device... Ok Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. ChallengeData is missing in server response ***Hints*** 1. Check your Internet connection. 2. If problem persist, contact the admin. Restarting the phone... Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 630 (RM-976) Sw Version: 02040.00019.15235.28006 Product Code: 059V9Q6 IMEI: 357138065xxxxxx NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. I did sw reflash with LumiarecoveryTool ,the problem remains .... ??? Please if someone can help. |
11-20-2017, 15:11 | #84 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | Quote:
Strpi se | |
12-10-2017, 06:49 | #88 (permalink) |
Freak Poster Join Date: Nov 2015 Location: INDIA
Member: 2482400 Status: Offline Sonork: 100.1677259 Thanks Meter: 115 | unlocki error *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 635 (RM-975) Sw Version: 02173.00000.15154.50006 Product Code: 059W663 IMEI: 356454063027485 NETWORK LOCK: ACTIVE PHONE LOCKED Connecting to server... Loading device info... Setting phone to TestMode... Updating devices list. Done! Updating devices list. Done! Flashing RAM Image. Image flashed successfuly, now it will boot. If takes more than 5 seconds, please reconnect USB. Updating devices list. Done! Updating devices list. Done! Connecting to device... Ok Sending data to server... Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. An error occurred while passing secure commands to terminal ***Hints*** 1. There are communication errors between PC and phone. Try restart the unlock process. Restarting the phone... Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 635 (RM-975) Sw Version: 02173.00000.15154.50006 Product Code: 059W663 IMEI: 356454063027485 NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. plz halp me |
