12-20-2017, 03:41 | #91 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | rm 975 cricket failed Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 635 (RM-975) Sw Version: 02173.00000.15154.50006 Product Code: 059W663 IMEI: 35645406068xxxx NETWORK LOCK: ACTIVE PHONE LOCKED Connecting to server... Loading device info... Setting phone to TestMode... Updating devices list. Done! Updating devices list. Done! Flashing RAM Image. Image flashed successfuly, now it will boot. If takes more than 5 seconds, please reconnect USB. Updating devices list. Done! Updating devices list. Done! Connecting to device... Ok Sending data to server... Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. An error occurred while passing secure commands to terminal ***Hints*** 1. There are communication errors between PC and phone. Try restart the unlock process. Restarting the phone... Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 635 (RM-975) Sw Version: 02173.00000.15154.50006 Product Code: 059W663 IMEI: 35645406068xxxx NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. wrote some different firmwares but the end it still locked.. |
12-20-2017, 17:45 | #92 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
01-28-2018, 16:03 | #93 (permalink) |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | Updating devices list. Done! Updating devices list. Done! Connecting to device... Ok Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. ChallengeData is missing in server response ***Hints*** 1. Check your Internet connection. 2. If problem persist, contact the admin. Restarting the phone... Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! PHONE LOCKED |
01-29-2018, 09:58 | #94 (permalink) | |
which version? make test server connection first | |
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post: |
02-05-2018, 15:00 | #95 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2018951 Status: Offline Thanks Meter: 2 | *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 550 (RM-1127) Sw Version: 01078.00042.16352.50006 Product Code: 059X6L0 IMEI: 3536910734xxxxx NETWORK LOCK: ACTIVE PHONE LOCKED Testing connection with Unlock Server ... FAIL |
02-05-2018, 17:39 | #96 (permalink) |
Freak Poster Join Date: May 2013 Location: Ireland, Uk
Member: 1944119 Status: Offline Sonork: 100.1666719 Thanks Meter: 38 | *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 640 LTE (RM-1072) Sw Version: 02177.00000.15184.36001 Product Code: 059X4D7 IMEI: 351858076054721 NETWORK LOCK: ACTIVE PHONE LOCKED An error while downloading Test Mode DataPackageInfo. Reason: Unable to connect to the remote server |
02-06-2018, 18:11 | #97 (permalink) |
Member: 1944119 Status: Offline Sonork: 100.1666719 Thanks Meter: 38 | *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 640 LTE (RM-1072) Sw Version: 02177.00000.15184.36001 Product Code: 059X4D7 IMEI: 351858076054721 NETWORK LOCK: ACTIVE PHONE LOCKED Connecting to server... Loading device info... Setting phone to TestMode... Updating devices list. Done! Updating devices list. Done! Flashing RAM Image. Image flashed successfuly, now it will boot. If takes more than 5 seconds, please reconnect USB. Updating devices list. Done! Updating devices list. Done! Connecting to device... Ok Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. Couldn't access to secure area. ***Hints*** 1. Do not unplug your phone while flashing RAM image. 2. If windows is trying to update the USB driver, unplug it and plug it again. 3. If problem persist, try restart the unlock process again. Restarting the phone... Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 640 LTE (RM-1072) Sw Version: 02177.00000.15184.36001 Product Code: 059X4D7 IMEI: 351858076054721 NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 640 LTE (RM-1072) Sw Version: 02177.00000.15184.36001 Product Code: 059X4D7 IMEI: 351858076054721 NETWORK LOCK: ACTIVE PHONE LOCKED Flashed fone same think cant unlock pleeeeeeeeeeease fixxxxxxxxxxx |
02-07-2018, 20:41 | #98 (permalink) | |
02-08-2018, 13:15 | #99 (permalink) |
Freak Poster Join Date: Apr 2007 Location: viet nam
Member: 484531 Status: Offline Thanks Meter: 69 | Connecting to server... Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Nokia Lumia 521 (RM-917) Sw Version: 3058.50000.1439.0042 Product Code: 059S0B4 IMEI: 355913056848158 NETWORK LOCK: ACTIVE SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. why whatsapp |
02-09-2018, 20:02 | #100 (permalink) | |
this type issue happen for many causes so we need check | |
02-11-2018, 09:33 | #103 (permalink) |
Member: 484531 Status: Offline Thanks Meter: 69 | sever dow please check Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Nokia Lumia 521 (RM-917) Sw Version: 3058.50000.1439.0042 Product Code: 059S0B4 IMEI: 352363063077685 NETWORK LOCK: ACTIVE PHONE LOCKED Connecting to server... Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. The remote name could not be resolved: 'nkwp8.is-by.us' ***Hints*** 1. Check your Internet connection. 2. Check the authentication token. 3. Check the client app's version. Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Nokia Lumia 521 (RM-917) Sw Version: 3058.50000.1439.0042 Product Code: 059S0B4 IMEI: 352363063077685 NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. |
