Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > Gmunlocker(powered by GSMideazone)
Old 12-20-2017, 03:41   #91 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 174
rm 975 cricket failed
Updating devices list. Done!
Loading device info (Client Version 4.5.0.1). Done!
***Device Info
Model: Lumia 635 (RM-975)
Sw Version: 02173.00000.15154.50006
Product Code: 059W663
IMEI: 35645406068xxxx
NETWORK LOCK: ACTIVE
PHONE LOCKED
Connecting to server...
Loading device info...
Setting phone to TestMode...
Flashing RAM Image.
Image flashed successfuly, now it will boot.
If takes more than 5 seconds, please reconnect USB.
Connecting to device... Ok
Sending data to server...
Process completed with ERRORS.
***Wait for reboot to confirm the SIMLock status.[Reasons]
1. An error occurred while passing secure commands to terminal
***Hints***
1. There are communication errors between PC and phone. Try restart the unlock process.
Restarting the phone...
***Device Info
PHONE LOCKED
SIM Unlock Failed
*HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure.
wrote some different firmwares but the end it still locked..
Old 12-20-2017, 17:45   #92 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
***Device Info
PHONE LOCKED
Flashing RAM Image.
***Hints***
***Device Info
PHONE LOCKED
SIM Unlock Failed
whatsapp +8801911954639
Old 01-28-2018, 16:03   #93 (permalink)
GSM Deals's Avatar
Member: 3936
Thanks Meter: 237
1. ChallengeData is missing in server response
***Hints***
1. Check your Internet connection.
2. If problem persist, contact the admin.
PHONE LOCKED
Old 01-29-2018, 09:58   #94 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
***Hints***
PHONE LOCKED
which version?
make test server connection first
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post:
Old 02-05-2018, 15:00   #95 (permalink)
Member: 2018951
Thanks Meter: 2
*** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 ***
Hints
1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed.
2. Need view phone info? Connect it and press 'Get Info' button.
3. Select as many rows as you want and press Ctrl+C to copy it content.
4. More than one phone connected? Connect the device to unlock.
5. Use reload button for rescan the connected devices.
Application info
Version 4.5.0.1
Copyright © 2017
Created by dk
Enjoy it ;-)
***Device Info
Model: Lumia 550 (RM-1127)
Sw Version: 01078.00042.16352.50006
Product Code: 059X6L0
IMEI: 3536910734xxxxx
PHONE LOCKED
Testing connection with Unlock Server ... FAIL
Old 02-05-2018, 17:39   #96 (permalink)
Member: 1944119
Sonork: 100.1666719
Thanks Meter: 38
Hints
Application info
Version 4.5.0.1
Copyright © 2017
Created by dk
Enjoy it ;-)
***Device Info
Model: Lumia 640 LTE (RM-1072)
Sw Version: 02177.00000.15184.36001
Product Code: 059X4D7
IMEI: 351858076054721
PHONE LOCKED
An error while downloading Test Mode DataPackageInfo.
Reason: Unable to connect to the remote server
Old 02-06-2018, 18:11   #97 (permalink)
Member: 1944119
Sonork: 100.1666719
Thanks Meter: 38
Hints
Application info
Version 4.5.0.1
Copyright © 2017
Created by dk
Enjoy it ;-)
***Device Info
PHONE LOCKED
Flashing RAM Image.
1. Couldn't access to secure area.
***Hints***
1. Do not unplug your phone while flashing RAM image.
2. If windows is trying to update the USB driver, unplug it and plug it again.
3. If problem persist, try restart the unlock process again.
***Device Info
PHONE LOCKED
SIM Unlock Failed
***Device Info
PHONE LOCKED
Flashed fone same think cant unlock pleeeeeeeeeeease fixxxxxxxxxxx
Old 02-07-2018, 20:41   #98 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
Hints
Application info
Version 4.5.0.1
Copyright © 2017
Created by dk
Enjoy it ;-)
***Device Info
PHONE LOCKED
Flashing RAM Image.
***Hints***
***Device Info
PHONE LOCKED
SIM Unlock Failed
***Device Info
PHONE LOCKED
Old 02-08-2018, 13:15   #99 (permalink)
Member: 484531
Thanks Meter: 69
***Device Info
Model: Nokia Lumia 521 (RM-917)
Sw Version: 3058.50000.1439.0042
Product Code: 059S0B4
IMEI: 355913056848158
SIM Unlock Failed
why whatsapp
Old 02-09-2018, 20:02   #100 (permalink)
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
***Device Info
SIM Unlock Failed
why whatsapp
this type issue happen for many causes
so we need check
Old 02-10-2018, 11:42   #101 (permalink)
Member: 67805
Thanks Meter: 364
is server down?
Old 02-10-2018, 12:11   #102 (permalink)
Member: 67805
Thanks Meter: 364
ok, its unlocked
PHONE UNLOCKED
The Following User Says Thank You to MOBICOM For This Useful Post:
Old 02-11-2018, 09:33   #103 (permalink)
Member: 484531
Thanks Meter: 69
sever dow please check
***Device Info
IMEI: 352363063077685
PHONE LOCKED
1. The remote name could not be resolved: 'nkwp8.is-by.us'
***Hints***
2. Check the authentication token.
3. Check the client app's version.
***Device Info
PHONE LOCKED
SIM Unlock Failed
Old 02-13-2018, 13:05   #104 (permalink)
Member: 236667
Thanks Meter: 12
Does it work with Lumia 550 windows 10 ?
Old 02-16-2018, 07:25   #105 (permalink)
Member: 1957238
Thanks Meter: 80
yes supported LUMIA 550 RM-1127
The Following User Says Thank You to Kukuphilmur For This Useful Post:
Page generated in 0.29025 seconds with 9 queries
