02-16-2018, 17:22 | #106 (permalink) |
Freak Poster Join Date: Sep 2014 Location: Guinea Age: 28
Member: 2260409 Status: Offline Thanks Meter: 27 | Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Restarting the phone... Updating devices list. Done! Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. An error occurred while passing secure commands to terminal ***Hints*** 1. There are communication errors between PC and phone. Try restart the unlock process. Restarting the phone... Updating devices list. Done! |
02-16-2018, 17:53 | #107 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1168485 Status: Offline Thanks Meter: 36 | i can't unlock my phone the problem from phone or program i flash it 2 times by windows recovery tool *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Updating devices list. Done! Connecting to server... Loading device info... Setting phone to TestMode... Updating devices list. Done! Updating devices list. Done! Flashing RAM Image. (27.19 %) Updating devices list. Done! Updating devices list. Done! Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. No phone found in Test Mode Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 635 (RM-974) Sw Version: 02040.00019.15235.28002 Product Code: 059W8V7 IMEI: 359743063191458 NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. Last edited by boudi_hakerz; 02-16-2018 at 18:01. |
02-16-2018, 21:11 | #108 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
02-20-2018, 08:44 | #109 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Your_Home Age: 38
Member: 413053 Status: Offline Sonork: 100.114351 Thanks Meter: 458 | lumia unlock problim 920 sir facing this ishuuu Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. ChallengeData is missing in server response ***Hints*** 1. Check your Internet connection. 2. If problem persist, contact the admin. Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. ChallengeData is missing in server response ***Hints*** 1. Check your Internet connection. 2. If problem persist, contact the admin. kindelly |
02-20-2018, 17:53 | #110 (permalink) | |
try unlock again | |
02-21-2018, 21:55 | #111 (permalink) | |
Freak Poster Join Date: May 2014 Location: aw
Member: 2180997 Status: Offline Thanks Meter: 6 | lumia unlock error Quote:
still same problem Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Restarting the phone... Updating devices list. Done! Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. An error occurred while passing secure commands to terminal ***Hints*** 1. There are communication errors between PC and phone. Try restart the unlock process. Restarting the phone... Updating devices list. Done! | |
02-21-2018, 21:56 | #112 (permalink) |
Member: 2180997 Status: Offline Thanks Meter: 6 | still same problem after disable firewall and antivirous Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Restarting the phone... Updating devices list. Done! Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. An error occurred while passing secure commands to terminal ***Hints*** 1. There are communication errors between PC and phone. Try restart the unlock process. Restarting the phone... Updating devices list. Done! |
02-21-2018, 22:21 | #113 (permalink) | |
will check details | |
02-26-2018, 18:03 | #114 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. Invalid Authentication Token ***Hints*** 1. Check your Internet connection. 2. Check the authentication token. 3. Check the client app's version. |
02-26-2018, 18:56 | #115 (permalink) | |
it is pc issue | |
03-08-2018, 05:55 | #116 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1743727 Status: Offline Thanks Meter: 76 | ***Device Info Model: Nokia Lumia 820 (RM-825) Sw Version: 3051.50009.1424.0030 Product Code: 059R1W9 IMEI: 35************ NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. Connecting to server... Loading device info... Setting phone to TestMode... Updating devices list. Done! Updating devices list. Done! Connecting to device... Ok Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. ChallengeData is missing in server response ***Hints*** 1. Check your Internet connection. 2. If problem persist, contact the admin. Restarting the phone... Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Nokia Lumia 820 (RM-825) Sw Version: 3051.50009.1424.0030 Product Code: 059R1W9 IMEI: 35*********** NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. |
03-16-2018, 16:14 | #117 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: Abidjan Age: 38
Member: 1418143 Status: Offline Thanks Meter: 353 | having this issue with RM-1152 . Quote:
03-20-2018, 09:45 | #118 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2348879 Status: Offline Thanks Meter: 0 | Restarting the phone... Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. An error occurred while passing secure commands to terminal ***Hints*** 1. There are communication errors between PC and phone. Try restart the unlock process. i have same problem |
