08-18-2018, 09:07 | #156 (permalink) |
Junior Member Join Date: Dec 2005 Location: Ukraine, Cherkassy
Member: 205049 Status: Offline Thanks Meter: 0 | I used client but unlock failed. Phone 920 Phone RM821, is blocked by the Austrian operator A1. On the advice of the program flashed (using the button flash device in 4.5.0.1), but still unlock failed. Tried 2 versions of the program 4.3 and 4.5.0.1. Log operations below. Thanks for the quick response |
08-18-2018, 09:25 | #157 (permalink) |
Member: 205049 Status: Offline Thanks Meter: 0 | Log *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Nokia Lumia 920 (RM-821) Sw Version: 3051.50009.1424.0004 Product Code: 059R8M3 IMEI: 354149059638194 NETWORK LOCK: ACTIVE PHONE LOCKED Connecting to server... Loading device info... Setting phone to TestMode... Updating devices list. Done! Updating devices list. Done! Connecting to device... Ok Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. ChallengeData is missing in server response ***Hints*** 1. Check your Internet connection. 2. If problem persist, contact the admin. Restarting the phone... Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Nokia Lumia 920 (RM-821) Sw Version: 3051.50009.1424.0004 Product Code: 059R8M3 IMEI: 354149059638194 NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. Updating devices list. Done! |
08-24-2018, 19:11 | #158 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
click verify for refund money | |
08-25-2018, 12:59 | #159 (permalink) |
Freak Poster Join Date: Jun 2009 Location: GV, Brazil
Member: 1064466 Status: Offline Thanks Meter: 34 | *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! Updating devices list. Done! An error while downloading Test Mode DataPackageInfo. Reason: Impossível conectar-se ao servidor remoto An error while downloading Test Mode DataPackageInfo. Reason: Impossível conectar-se ao servidor remoto An error while downloading Test Mode DataPackageInfo. Reason: Impossível conectar-se ao servidor remoto Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 550 (RM-1127) Sw Version: 01078.00042.16352.50013 Product Code: 059X699 IMEI: 353691073348061 NETWORK LOCK: ACTIVE PHONE LOCKED An error while downloading Test Mode DataPackageInfo. Reason: Impossível conectar-se ao servidor remoto Firewall is off, how to solve? |
08-27-2018, 12:35 | #160 (permalink) | |
try v3.0 here post result here | |
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post: |
09-10-2018, 07:56 | #161 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 1520 (RM-940) Sw Version: 02540.00019.14484.37028 Product Code: 059T5X8 IMEI: 358*******19034 NETWORK LOCK: ACTIVE PHONE LOCKED what is the problem? |
09-10-2018, 10:31 | #162 (permalink) | |
try 4.3 version send info | |
