01-03-2019, 18:11 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: rochdale uk
Member: 396778 Status: Offline Thanks Meter: 155 | Maximum temp error I have just bought irework but having some issues with it. I am trying to select custom operation and keep getting this error "[erro] Current selected heater temperature target 300 is higher than maximum allowed of 99". can you please help me out. thanks |
01-03-2019, 23:22 | #2 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @mobileunlockers You have to Adjust Custom Settings from iRework Settings Tab, Check Manual Here. Create New Setting & adjust temperature to desired degree. Go Back to Main Tab and Select the new Custom Setting you just created. MFC Team |
01-04-2019, 11:09 | #3 (permalink) |
Member: 396778 Status: Offline Thanks Meter: 155 | thanks. its done now. i have got question fro you, When removing any IC with irework will this not messed glued IC and make dry solder under other IC,s? |
01-05-2019, 13:33 | #4 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @mobileunlockers Our Factory Settings will not Mess with Glue nor Damage any parts because of the Precision and Extensive Testing done on many Board Types. Custom Settings however, we cannot be certain of, so be Careful in choosing a custom setting unless you are sure about this temperature. MFC Team |
