Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iREWORK Station
Old 04-03-2019, 13:43   #1 (permalink)
tgsm's Avatar
Member: 13827
Thanks Meter: 10
Is it possible to safely use for ip7 audio IC ?
Needed help.Is it safe to use irework for iphone 7 audio IC safe desolder-solder?
what option should I use?
temperature?
Heater?
External ?
no preconfigured mode?
how to check board temperature? "External Temp" ?
any advice not to heat baseband
Old 04-04-2019, 12:03   #2 (permalink)
tgsm's Avatar
Member: 13827
Thanks Meter: 10
I found myself m0th*krs
you can use preset 180 iphone X LR separate board works in preheat ip7 fine
Old 04-04-2019, 12:48   #3 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 5,029
Sure you can do this !
Apply option 5 (If want to do very fast remove, Can using hot air heating the top of the IC a little bit, then remove IC by related tools)
and you can apply partial heating by iREWORK like picture :
Page generated in 0.20163 seconds with 7 queries
