01-20-2017, 13:47 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: in your mind
Member: 1315205 Status: Offline Thanks Meter: 21 | unable to install soft i try to install version 1.0.6 i get only errors what to do now?ImageUploadedByTapatalk1484916757.244816.jpg Last edited by 7ope; 01-20-2017 at 13:52. Reason: photo |
03-02-2017, 15:22 | #3 (permalink) |
Registered User Join Date: Dec 2012 Location: canada
Member: 1848477 Status: Offline Thanks Meter: 3 | Same problem here tried to install software i get an error, then i tried installing drivers manually and messing around, drivers installed ok but i try to run SHP_EN_106.exe i get error 0xc000007b |
03-03-2017, 15:06 | #5 (permalink) |
Member: 1848477 Status: Offline Thanks Meter: 3 | Are you from mfcbox staff ? Their support via email tells me to try another system but i've tried it just won't work My os is in French not english and this is why the installation package won't run.. I need either a portable version or a fixed installer, this is frustrating i can't use the product And i've tried a clean installed laptop as well same issue |
03-03-2017, 15:14 | #6 (permalink) |
Member: 1848477 Status: Offline Thanks Meter: 3 | Ok this is frustrating, installed a fresh VM with ENGLISH windows 10 x64, software installed ok but won't run After clean install it works but gives errors with missing libusb files, but then after copying files from C:\SHP\Driver\SHPDrivers\amd64 to c:\SHP\ it still doesn't work, errors out error 0xc000007b Grrrr. please fix your installer! |
03-03-2017, 23:02 | #8 (permalink) |
Member: 1848477 Status: Offline Thanks Meter: 3 | Still not working.. Same error, seemed like the exact same files I was able to extract the files and install the drivers by the way, it's the EXE that won't run at all tested on 3 machines ! The pre-requisites were all installed also. |
03-04-2017, 00:46 | #9 (permalink) |
Member: 1315205 Status: Offline Thanks Meter: 21 | unable to install soft i confirm that installer get problem with: - a not English version of windows ( check Administrator ) and - normal mode driver installation Last edited by 7ope; 03-04-2017 at 00:49. Reason: add |
03-04-2017, 17:53 | #11 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | You can download the zip file from this link: https://mega.nz/#!PQ9kibjQ!0RPJTuRnr...KrDfdod0jh32C4 A,unzip that to c:/shp folder B, manually install the drivers
D, Click main software of SHP will start to work |
