Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help |
11-28-2017, 08:18 | #2 (permalink) | |
Junior Member Join Date: Jan 2017 Location: bhadra Age: 31
Member: 2678441 Status: Offline Sonork: xyz Thanks Meter: 0 | Quote:
12-11-2017, 10:16 | #4 (permalink) | |
Junior Member Join Date: Aug 2017 Location: A Coruņa/Galicia/Espaņa
Member: 2746278 Status: Offline Thanks Meter: 1 | Quote:
Hi! I have the same problem in two redmi 4. The coils are open but the diodes are apparently ok. What is the value of coils and diodes? I donīt have schematic. Thank you | |
The Following User Says Thank You to odemontealto For This Useful Post: |
02-11-2018, 06:54 | #10 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2810066 Status: Offline Thanks Meter: 4 | is this problem with the LCD backlight not coming up after waking up ? if so, I have 2 types of xiaomi redmi note 4 ; 1 is using MTK cpu and the other is snapdragon qualcomm, this problem only affects xiaomi redmi note 4 with qualcomm cpu. can somebody share the capacitor and coil values ? tq |
The Following User Says Thank You to cresstt For This Useful Post: |
02-11-2018, 17:11 | #11 (permalink) | |
Member: 2810066 Status: Offline Thanks Meter: 4 | Quote:
diode is WSB5507W-2 and inductor coil is 10uH | |
The Following 3 Users Say Thank You to cresstt For This Useful Post: |
03-02-2018, 04:03 | #13 (permalink) |
Member: 2673667 Status: Offline Thanks Meter: 2 | My prob is solve after long period 30 days i lastly found due to supply is brack in power ic to diod not to easy but hard work i find supply through magnify glass |
The Following User Says Thank You to javaid ganie For This Useful Post: |
04-10-2018, 17:03 | #15 (permalink) | |
Junior Member Join Date: May 2011
Member: 1581438 Status: Offline Thanks Meter: 1 | dear javeed Quote:
i also have a mi note 4 water damaged... problem is no lcd light..... please reply sajjad 7006211200 | |
The Following User Says Thank You to ssajjad For This Useful Post: |
