Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi > Xiaomi Hardware Repair
Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help
Old 02-22-2019, 12:06   #1 (permalink)
SHIBU13's Avatar
Member: 592544
Thanks Meter: 95
mi note 6 pro lcd light
need mi note6 pro lcd light ways
Old 05-01-2019, 10:51   #2 (permalink)
Boyofkashmir's Avatar
Member: 642074
Thanks Meter: 1,953
Help mi note 6 pro light ways if anyone have...........
Old 07-13-2019, 11:20   #3 (permalink)
Member: 2504572
Thanks Meter: 25
need mi note 6 pro lcd light ways jumper solution
The Following User Says Thank You to gsmshakib For This Useful Post:
Old 07-29-2019, 01:50   #4 (permalink)
Member: 2558205
Thanks Meter: 8
https://postimg.cc/GBtmXb1m
The Following User Says Thank You to balaawi6 For This Useful Post:
Old 09-12-2019, 19:55   #5 (permalink)
daroas's Avatar
Member: 194078
Thanks Meter: 148
i want solution for Redmi Note 6 PRO blacklight too
Old 09-14-2019, 06:33   #6 (permalink)
Crazy Poster
Member: 954742
Thanks Meter: 20
Fastest repair backlight led driver steps ... Without schematics
1. Find serial diode first near lcd connector or pmu block
2. The serial diode connected with serial inductor
3. The both of them has the same line and voltages with vbatt or vph_power
4. Find the pulldown resistor ( resistor which one of it pin connected to the ground ) arround the unit / led driver ic as enable /bl_pwm
5. Check the serial diode connected to the pin of lcd connector or resistol (serial) near lcd connector
6. Make a jumper cable from cathode (serial diode) to voltmeter and set voltmeter in 50v dc
7. Set power supply to 4.0v then connect to the vbatt connector as power source
8. Set analog multi tester in 1x ohm calibration then put the red probe to the ground, and the black probe pointed to the pulldown resistor as an enable for bl led driver
9. The digital multitester will shown the voltage value as output voltage from bl led driver booster regulator ... About 15-30v
that's mean the bl led driver work normally
post the result
cmiiw
Old 03-18-2020, 07:26   #7 (permalink)
Member: 2702982
please give me display graphics solution In mi note 6 pro
Old 03-25-2020, 16:04   #8 (permalink)
uniontelecom's Avatar
Member: 1538904
Sonork: 100.1603095
Thanks Meter: 191
Page generated in 0.16752 seconds with 7 queries
