Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help |
11-08-2017, 19:04 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | mi4i charging not store the set shows charging but unable to charger it , we have changed the battery and sub pcb but problem remains same . help ... |
03-12-2018, 06:46 | #2 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2723216 Status: Offline Thanks Meter: 0 | I having same issue and now no display but display backlight shows it is on. Problem started from charging issue *** same as yours now i removed one component called condensor and then charging light was stable with no display. |
03-26-2018, 15:05 | #3 (permalink) |
Junior Member Join Date: Dec 2013 Location: coimbatore.india Age: 32
Member: 2081494 Status: Offline Sonork: 100.1650349 Thanks Meter: 9 | some idea can work.. incase power management ic damage charging backup not confirm. some android mobiles same problem changing power ic after problem solve.try your own risk..... |
