Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi > Xiaomi Hardware Repair
Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help
Old 03-24-2017, 16:59   #1 (permalink)
Member: 1143614
Thanks Meter: 5
Mi5 - dead, no power
My Mi5 went dead in pocket . After connecting it with charger ( original from Xiaomi ) it start to heat up on back side but no LED or screen light up. I connected it to PC and try to flash a new software through MiFlash tool and it went without errors, but the phone still wont turn on . Fastboot and recovery mode works ( PC recognize at all when Mi5 is in fastboot and recovery mode ) . So I tried to left it turned on ( disconnect battery, reconnect it again and press power button for a second ) . It is start to heat up again . After 10-12h I connect it to charger and it shows me red LED light . I left it on charger for all night, in the morning the LED was not light up , but when I try to turn it on , then LED light up green ( weaker and stronger , blinking ) .
With fastboot command I see that the battery is charging very well ( when it is empty, voltage is about 3.447V , when it is fully charged it is 4.663V ) .
Is that problem with my battery or maybe something else as PMIC ( PMI8994 ) ?
Old 03-25-2017, 21:20   #2 (permalink)
rrvius's Avatar
Member: 1821491
Sonork: Never give up
Thanks Meter: 35
Check with new battery not work check shots in heating areas most in case mi LCD back light section failure Chq and post
Old 03-26-2017, 00:34   #3 (permalink)
Member: 1143614
Thanks Meter: 5
I will try with new battery.
Device is very hot all around CPU and PMIC when it is on charger .
Old 04-28-2017, 10:12   #4 (permalink)
Member: 634596
Thanks Meter: 25
i had problem whit lcd back light. so where is the place of ic light
Old 04-29-2017, 14:05   #5 (permalink)
Member: 1143614
Thanks Meter: 5
I solve the problem by changing PMI8994 IC chip.
But now device is locked to Mi account of previous owner , he forgot email and password so now the phone is useless because I cant remove that account from phone.
Already contacted Xiaomi with all details and pictures of phone, imei sticker on the box and a receipt fron shop to prove that is not stolen but they cant help .
I dont have BST Dongle , so is there anybody that can help to remove Mi account ?
Old 04-29-2017, 15:45   #6 (permalink)
Member: 2379235
Thanks Meter: 38
bro simply downgrade it with miui 7.
Old 04-29-2017, 19:20   #7 (permalink)
Member: 1143614
Thanks Meter: 5
Yes, I already downgraded to Global 7.2.4.0 in MiFlash with option " flash all " but after setup I get an error " This device is locked " .
Is there any other method ?
Old 09-19-2017, 03:58   #8 (permalink)
Member: 2756811
use deep flash cable for enter edl mode.
Old 10-02-2017, 08:13   #9 (permalink)
Member: 2717363
Old 03-05-2018, 19:11   #10 (permalink)
Member: 330082
Thanks Meter: 22
power chip change for solition ;
https://www.youtube.com/watch?v=T-xjeXJtJlM
Old 03-23-2018, 16:38   #11 (permalink)
Member: 2823833
I have the same problem too.
Old 06-30-2018, 21:38   #12 (permalink)
Member: 1571845
Thanks Meter: 3
Hello! Is there any possibility that you have humidity on the motherboard?
Old 07-10-2018, 08:32   #13 (permalink)
Member: 2432125
Thanks Meter: 21
__________________________________________________ __________
Hacker AN
Answer:
Replacement the pmi8994
[IMG][/IMG]
100% Work
Old 08-21-2018, 14:37   #14 (permalink)
Member: 930668
Thanks Meter: 5
Good stuff, thank you for sharing.
The Following User Says Thank You to jackbauer_swat For This Useful Post:
Page generated in 0.20137 seconds with 8 queries
