Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help |
09-06-2017, 15:42 | #1 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2753881 Status: Offline Thanks Meter: 0 | Need help repairing Redmi 2 Someone said there could be short circuiting in the charging circuit because of which it is happening like that, but when I checked the PCB, there was nothing much I can do, except connect and disconnect the cable, after each reassembly sometimes the touchscreen works sometimes the touchscreen doesn't work. I was also advised to wash the PCB in isopropyl alcohol, will this eliminate the problem? |
01-17-2019, 08:09 | #3 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2022100 Status: Offline Thanks Meter: 0 | redmi 2 touch screen not functioning need help repair xioami remdi 2,touch screen not functioning i already replace brand new touch screen and digitizer, but the touch screen still not working. need help, |
01-18-2019, 09:07 | #4 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 226190 Status: Offline Thanks Meter: 22 | Any android phone touch screen hang suddenly or after factory reset, solved 100% ANY ANDROID PHONE TOUCH SCREEN HANG SUDDENLY OR AFTER FACTORY RESET, SOLVED 100% https://www.youtube.com/watch?v=7siceuJATNE |
The Following User Says Thank You to vaskar For This Useful Post: |
