Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi > Xiaomi Hardware Repair
Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help
Old 04-22-2019, 12:50   #1 (permalink)
Member: 2430631
Thanks Meter: 40
Redmi 6a resistor value?
Can someone help me with the value of this resistor?
The phone was water damaged and the resistor completely corroded, tried replacing with several with approximately the same value as the ones around it, and with a wire but i get no picture
https://imgur.com/a/PFlNS3K
Old 04-22-2019, 14:42   #2 (permalink)
Member: 182653
Thanks Meter: 115
0 ohm (like a fuse), measured at redmi 6
The Following User Says Thank You to smtel For This Useful Post:
Old 04-22-2019, 14:52   #3 (permalink)
Member: 2430631
Thanks Meter: 40
Thank you bro
Then it is not the only problem, it should work when i make a bridge with a wire but it does not. The capacitor next to it was damaged as well but i replaced it and still no picture. I will have to try with a new display
Sent from my WAS-LX1 using Tapatalk
Old 04-22-2019, 21:31   #4 (permalink)
Member: 182653
Thanks Meter: 115
May be MT6371P is damage - this often happens after water damage(if LCD dark, but the sensor responds)
there is a solution for the backlight from another forum - try this:
Old 04-22-2019, 23:12   #5 (permalink)
Member: 2430631
Thanks Meter: 40
I thoughtit might be back light but the touch does work either and when i flash a bright light on the display there is no picture. I don't ha e a new display to try so i will wait till it comes and try
Thank you anyway
Page generated in 0.16443 seconds with 10 queries
