Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help |
04-22-2019, 12:50 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Macedonia
Member: 2430631 Status: Offline Thanks Meter: 40 | Redmi 6a resistor value? The phone was water damaged and the resistor completely corroded, tried replacing with several with approximately the same value as the ones around it, and with a wire but i get no picture https://imgur.com/a/PFlNS3K |
04-22-2019, 14:52 | #3 (permalink) |
Member: 2430631 Status: Offline Thanks Meter: 40 | Thank you bro Then it is not the only problem, it should work when i make a bridge with a wire but it does not. The capacitor next to it was damaged as well but i replaced it and still no picture. I will have to try with a new display Sent from my WAS-LX1 using Tapatalk |
04-22-2019, 21:31 | #4 (permalink) |
Freak Poster Join Date: Sep 2005 Location: SPB Age: 45
Member: 182653 Status: Offline Thanks Meter: 115 | May be MT6371P is damage - this often happens after water damage(if LCD dark, but the sensor responds) there is a solution for the backlight from another forum - try this: |
04-22-2019, 23:12 | #5 (permalink) | |
Member: 2430631 Status: Offline Thanks Meter: 40 | Quote:
Thank you anyway Sent from my WAS-LX1 using Tapatalk | |
