Franky_36 | 12-08-2018 16:58 | Quote:
Originally Posted by motazkhater
(Post 13456241)
i think it hardware , do you have any solution | Good, even doing test point does not recognize the phone, the only solution is jtag, emmc, to make sure if you know about the material, dismantle the phone and if you have a microcosp do an ispección all over the plate, can also be that the charging connector, the pins of the charging connector or the charging connector itself needs to be changed because it is broken or damaged, if after the inspection everything is correct, it only remains as what I mentioned at the beginning of this message or post emmc or jtag, thank you and I hope I have helped you. |
