Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help |
12-06-2018, 20:33 | #2 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, when you connect the xiaomi with the usb cable to the computer, the computer recognizes it, look at the device manager and if it recognizes you it will be the qualcomm 9008 driver ?, you have some professional tool, mrt, umt, jellyfish pro, easy jtag plus, etc?. |
The Following User Says Thank You to Franky_36 For This Useful Post: |
12-08-2018, 16:58 | #5 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, even doing test point does not recognize the phone, the only solution is jtag, emmc, to make sure if you know about the material, dismantle the phone and if you have a microcosp do an ispección all over the plate, can also be that the charging connector, the pins of the charging connector or the charging connector itself needs to be changed because it is broken or damaged, if after the inspection everything is correct, it only remains as what I mentioned at the beginning of this message or post emmc or jtag, thank you and I hope I have helped you. |
12-08-2018, 17:48 | #7 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Do you apply this jumper, then check your device manager. if not detected check your charging port / main Flex Cable Ribbon part. When you do EDL jumper for Check, first try without battery, some phone batteries are also required if not recognized.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
01-16-2019, 15:12 | #9 (permalink) |
Freak Poster Join Date: Apr 2008 Location: alix
Member: 759802 Status: Offline Sonork: 100.1645948 Thanks Meter: 23 | ihave pormlem http://forum.gsmhosting.com/vbb/f999...mi-s2-2549627/ |
