Originally Posted by TheAirliners Hi guys, I would like to share with you some experiences with R-Sim Air 2, because I'm rather satisfied with using this solution. At start, be sure that you have a range in place, where iPhone will be activated (if it still can't reach a range, it may cause a lots of problems during the cracking process)
WHEN (.) MEAN DOTS IN URL, I CAN'T SET FULLY WORKING URL IN THE FORUM COS I'M A NEW USER
These are required to do if you want to get stable :
1. Install fresh copy of iOS 7.1.2 (not restored backup if you changed something with carrier bundle, etc. if restored - could cause problems with range)
2. Insert R-SIM AIR 2 along with you Sim card to activate the iPhone (I used Play Poland sim, if it shows "invalid sim card" just be patient and still try to activate it, I had success after few times)
3. If popup come - choose US Sprint - Iphone 5/5s/5c and next IOS 7.1/7.X if you have 7.1.1 or 7.1.2 (DON'T CHOOSE 7.0 FOR 7.1.1 OR 7.1.2! THAT'S BULL***T THAT IT AVOID THE ACTIVATION SCREEN!)
4. Deselect all cellular, internet data options.
5. Restart the phone
6. When restarted - jailbreak the phone, connecting the iPhone with your PC/Mac, using Pangu (pangu(.)io) and do steps required there.
7. Using Cydia, go Sources - Edit - Add - type "www(.)isamteam(.)com"
8. In repo options from isamteam select "All packages" and install "A:RSIM iOS 7 5s/5c/5"
9. Type "www(.)unlockit(.)co(.)nz" and set your APN settings, choosing your target carrier (mine is Play PL)
10. Use also Rpatch - this one for real remove the problem with activation, you'll never see it anymore, when iphone is out of range, it just start to search a new network without showing this annoying activation screen. But when your rpatch is installed, it's needed to activate it without wifi (required internet data so go to set it ON.), type the purchased activation code and OK.
What I noticed before - don't change anything with carrier bundles when using isamteam repo, the A: has been installed along with A1: which replace/rename the carrier bundle files automatically so it's useless to do it manually. The next is - don't use ir0setool - before when I tested, it made that the phone internet does not work, that's my experience.
I'm still testing this one and i'm really satisfied, maybe somebody has other experiences or questions? |
