E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
04-18-2004, 19:01 | #1 (permalink) |
Junior Member Join Date: Oct 2000 Location: London, UK
Member: 2247 Status: Offline Thanks Meter: 0 | Problem flashing A55 -> C55 I've been reading past threads but still can't find the answer. I want to convert my A55 to a C55 and unlock it as well. I tried both Freia 9/10 and Winswup to flash C55 firmware v18 to the phone, after flashing I try to power on the phone but it makes two 'click' noises. I try to unlock it, but it says 'update not accepted'. I've tried various settings but still can't get the phone to power on with the C55 firmware. Then.. I flashed it back to the original A55 firmware, and unlocked it successfully using Freia 10. Soo.. what am I doing wrong? I would like to convert it to a C55 and I'm using 98SE with USB cable. Thanks Pika |
04-18-2004, 20:21 | #2 (permalink) |
Insane Poster Join Date: Feb 2004 Location: Russia Age: 49
Member: 55536 Status: Offline Thanks Meter: 0 | If Your problem is unlocking and You don't need unlock A55, try "1" or "2": 1. Flash phone with bootcore (not fullflash!) from C55, then use latest winswup for C55 v.24 - c55_240101w.exe for flashing C55 firmware into phone (set first "precheck") - no unlock needed at all! 2. Or, after flashing C55 fubu, just restore Your original EEPROM (A55) from backup - no unlock needed too. If phone work well after all, but You found, that some menu items are missing, use SiemensQuickEepromFeatures 3.3 for writing "right" 71 EEPROM block. |
04-18-2004, 22:41 | #3 (permalink) |
Junior Member Join Date: Mar 2004 Age: 79
Member: 60083 Status: Offline Thanks Meter: 0 | Select boot type-->A55 new phones in freia ( 1 ) Read firmware a55 >> Read Flash ( 2 ) Read eeprom1 a55 >> Read Flash ( 3 ) Read bootcore a55 >> Read Flash ( 4 ) Backup battery a55 >> Miscellaneous > Backup Battery parameters from phone ( 5 ) Write firmware from c55 (.bin) >> Write Flash ( 6 ) Write eeprom1 from A55 (.bin) >> Write Flash ( 7 ) >> Miscellaneous > Restore battery parameters from phone ( 8 ) Write bootcore original a55 >> Write flash ( 9 ) >> Unlocking > direct unlock no mp is saved > Use Original IMEI (10) Update firmware with official siemens update (optional) Use java enabler Early_Bird_by_Skylord_ver1.3 to enable java |
04-20-2004, 04:11 | #4 (permalink) |
Member: 2247 Status: Offline Thanks Meter: 0 | I managed to flash the phone properly this time, but can't use the java enabler software. It just stays on 'scanning'. With the SiemensQuickEepromFeatures software, which options do I need ticked/unticked. Pika |
Problem with A55 ---> C55 | TurboDiesel | E-Gold Based Phones | 4 | 07-21-2005 11:35 |
A55 --> C55 | Mac Gyver | E-Gold Based Phones | 7 | 02-13-2004 17:44 |
English Procedure - A55 > C55 | jamie_r | E-Gold Based Phones | 22 | 01-28-2004 11:02 |
Siemens A55 > C55 | jamie_r | E-Gold Based Phones | 9 | 01-25-2004 12:40 |
