Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Apple Inc. Products
Apple Inc. Products iPhone 2G , iPhone 3G , iPhone 3GS , iPod , iPad , Apple TV
Old 03-16-2009, 17:31   #1
prasad3223
prasad3223's Avatar
Member: 259742
post ur request for cracks
Friends as i have seen many people asking for cracks,i want to see for any help i can do.
so if u have any request for cracks of applications from cydia or other plz notify here and i will help u as much as i can do
thanks,
Old 03-16-2009, 17:59   #2
prasad3223
prasad3223's Avatar
Member: 259742
17 in 1 Cracked Cydia Apps.
17 in 1 CRACKED Cydia applications.
- MobileGate
- SwirlyMMS
- AdBlock
- biteSMS
- Chronus
- ClearCam
- IntelliScreen
- iRealSMS
- Madvlock
- McallShow
- Mcleaner
- McoolPhone
- Mewseek
- MobileLog
- PdaNet
- Snapture
- VideoRecorder3G
http://ifile.it/vqamxb7
Remember to hit THANKS button...
All credits goes to the original crackers.
The Following 5 Users Say Thank You to prasad3223 For This Useful Post:
Old 03-16-2009, 18:04   #3
prasad3223
prasad3223's Avatar
Member: 259742
ClearCam 1.0.5 Cracked
Credit: Alzir from hackulo.us
App Name: ClearCam
Version: 1.0.5
Source : Cydia
Website: http://anonym.to?http://www.occipital.com/
removed the demo limitations and there's no need for trial or full unlock code.
UPDATE: 1.0.5 (.deb file)
DOWNLOAD ---> v1.0.5
How to: Install .deb files
P.S: If you have Lock down Enter any 16 characters to unlock.
Enjoy ;-)
hit thanks if useful
Old 03-16-2009, 18:07   #4
prasad3223
prasad3223's Avatar
Member: 259742
How to install an iPhone .deb?
  • Upload the .deb (Debian software package) file to your device's /tmp/ folder. Create the folder if it doesn't exists.
  • SSH into your device as the root user by issuing the following Terminal command:
    ssh root@192.168.123.88
    (You must replace 192.168.123.88 with your device's actual IP address.)
  • Next, quit Cydia if it is running, and issue the following Terminal command to start installation:
    dpkg -i /tmp/name.deb
    (Replace name.deb with the actual filename of your .deb file)
  • You may delete the .deb file after completing installation.
Old 03-16-2009, 18:17   #5
prasad3223
prasad3223's Avatar
Member: 259742
Fring
Fring cracked to work over Edge\3G with VOIP
Heres an .ipa that allows you to do VOIP voice calls over edge or 3G. Even though its unbearable even with wifi, it shows how easy it was to change a few strings and make it work
http://rapidshare.com/files/15103589...or_3G.ipa.html
I just deleted my old fring from itunes, synced it so it would uninstall it from the iphone and sync the new one in.
I am not the cracker, someone should reverse engineer it and see how they did it so we can do it for future versions of fring.
Old 03-30-2009, 05:29   #6
swyc
Member: 998127
hi Prassad3223, I'm new here. Just wan to check with u few things :-
1) Can I use DiskAid programme to upload the .deb file to my iPhone device ?
2) Upload the .deb (Debian software package) file to my device's /tmp/ folder. Create the folder if it doesn't exists. What name of the folder do I need to rename it ? Is it same as .deb file ? Or just put it as "folder" only ?
3) Is it to start "Terminal comman"d installation same as the "MobileTerminal" downloaded from Cydia ?
4) Just tom confirm with u :
Command 1) dpkg -i /tmp/name.deb
Command 2) dpkg-i/tmp/name.deb (Spacing Ok ?)
5) I tried but doesn't seems to work, 1st I use DiskAid to connect to my device and then create a FOLDER name as "Clearclearcam 1.0.5_iphoneos-arm" and I copy the clearcam 1.0.5_iphoneos-arm.deb into the folder then exit and open the MobileTerminal , by default the screen show as [ localhost:~ mobile$ dpkg -i /tmp/name.deb ] then I press return/enter but it doesn't seems to work at all. Did I miss any step ?
If possible can u attach some screen shots and more detail guide and email to me at shawnwyc@hotmail.com
Thanks
Regards,
Shawn
Old 03-30-2009, 06:14   #7
simranjots
Member: 989577
Thnks bro...do u hav mysms crack???????
Old 03-30-2009, 06:41   #8
eon
eon's Avatar
Member: 774786
mySMS 9.9.9.1
first install MySMS from Cydia. 9.9.9.1 should be the latest update. Then use the attachment:
You should know what to do. Install the thing and put those into the application folder and and Respring! After that go into MySMS from SpringBoard and click the left corner button, go down to the very bottom click Import/Export passwords, and click Import passwords from Notes Choose MySMS-Backup! There you go guys! Respring and go click that left corner button and see if that Register button has dissappeared!
Credits: kash123 @ Pr0x
thanks to Reilly
The Following 2 Users Say Thank You to eon For This Useful Post:
Old 03-30-2009, 09:29   #9
simranjots
Member: 989577
thanks to Reilly
but bro where i hav to store dese files through ssh? thnks
The Following User Says Thank You to simranjots For This Useful Post:
Page generated in 2.25510 seconds with 9 queries
