Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 07-25-2009, 21:06   #1 (permalink)
Member: 16938
Thanks Meter: 28
FPS-21 flashing problem
I'm have use FPS-21, but no one unit can't programme! Dose need to be FPS-21 activated for flashing?
Flashbus Rx buffer dump: 00000000000000000000000000000000000000000000000000 0000000000
Error! Phone program failed!
Error code D101
Flashing time: 0 min and 4 sec
All operations completed
Product flashing failed.
Trying via USB
Old 07-26-2009, 04:47   #2 (permalink)
Member: 894862
Thanks Meter: 21
yes it is activated, bro, what unit are you trying to update? because this error D101 is connection error between your box or your usb, try to use original usb. then what is the status of your phone right now? if its dead try to use no connection rather usb connection then press the power button after you start flashing
Old 07-26-2009, 14:38   #3 (permalink)
Member: 16938
Thanks Meter: 28
I'm use 100% original cables. Trying with good working phone N5320 (just whant to flash). Use NFPD USB/TCP connections - all the same! See attach.
Old 07-26-2009, 16:09   #4 (permalink)
Member: 9848
Thanks Meter: 144
Just for your information:
You don't need SX-4 for flashing any BB5 phone. It's only needed for FAID calculation when you flash DCT-4 phones.
Old 07-27-2009, 08:24   #5 (permalink)
Member: 894862
Thanks Meter: 21
Brother you cannot flash this unit without cu-4 or ss46 you badly needed this and internet connection connected to the back of your FPS 21, then go to file manage connection new choose TCP/IP connection then flash it
Old 07-27-2009, 08:32   #6 (permalink)
Member: 16938
Thanks Meter: 28
so, flashing (using FPS-21) are possible only via SS-62 + CU-4 (USB as FBUS) ?! What about CA-101 pluged into back USB FPS-21?
Old 07-27-2009, 08:54   #7 (permalink)
Member: 4263
Sonork: 100.1582330
Thanks Meter: 49
use USB only (not NFPD USB) with usb cable
Old 03-14-2010, 18:27   #8 (permalink)
Member: 7994
Thanks Meter: 20
need fps
Hi
need the box FPS 20-21
if you can get one i need
[email protected]
FPS-20 - fps-21 pinout pol98 Nokia Base Band 5 ( BB-5 ) 1 03-14-2010 18:26
Nokia FPS-10 vs. FPS-21 carloz Hardware Equipments for GSM 0 01-15-2010 16:39
Original Nokia Flash Prommer, FPS-21 \ FPS-10 \ FLS-5 For Best Price !!! GSMFLASCH Main Sales Section 0 09-15-2008 11:49
FPS-21 Flash Prommer Full set 40parts.. GSMFLASCH Main Sales Section 0 05-19-2008 11:57
Page generated in 0.18120 seconds with 11 queries
