#1 |
![]() ![]() ![]() ![]() Join Date: Apr 2008
Member: 751908 Status: Online Sonork: ZubairArain
KG195 "Waring: Invalid Charger"
LG KG195 warning "Warning: Invalid Charger" when connect charger. Any solution from anyone. plz urgent.
ZubairArain |
| The Following 3 Users Say Thank You to ZubairArain For This Useful Post: |
#2 |
Member: 1130822 Status: Offline Thanks: 0
| The Following 2 Users Say Thank You to rkhurramnazajk For This Useful Post: |
#3 |
![]() ![]() Join Date: Aug 2009
Member: 1087294 Status: Offline Thanks: 4
change original battery or original charger
insha ***** ur problem solved don't forget to say thanks |
| The Following 3 Users Say Thank You to bruightmobile For This Useful Post: |
#4 |
![]() Join Date: Jun 2006
Member: 299534 Status: Offline Thanks: 18
how to solve ''invalid charger''
1st.check the battery
2nd.check battery terminal 3rd.check charger's voltage often charger send increase voltage then start this problem so search a ok and geniune charger and check it......... i try this and set will be ok please don't forget for thanks
| The Following 2 Users Say Thank You to Faisa Farooq For This Useful Post: |
#5 |
Member: 906272 Status: Offline Thanks: 3
| The Following User Says Thank You to sihraja For This Useful Post: |
#6 |
Check central pin but problem is not solved.
#7 |
![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 642374 Status: Online Thanks: 37
just use nokia orginal charger and lg pin sirrrrrrrrrrrrrrrrrrr
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008
Member: 762034 Status: Offline Sonork: 100.1585274
| The Following User Says Thank You to guljee786 For This Useful Post: |
#9 |
Member: 562003 Status: Offline Thanks: 2
goooooooooooooooood brother
| Bookmarks |
| Thread Tools | |
| Display Modes | |
