Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > SonyEricsson > SonyEricsson Hardware-Repair Area
SonyEricsson Hardware-Repair Area Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-21-2009, 11:47   #1
ahhongchai
Member: 68833
k850 & c902 power ic(ab3100) hot very seriously pls hlp!!
does anyone face this case ?
i got a c902 and a k850 , phone never drop on water and look very clean on board...but the phone going very hot when power on also drain battery very fast .........
what i have done is:
1,clean the pcb
2,change new ab3100 but cannot power on ?some1 say need to program,but phone cannot detect by cruiser , setool and univesal box
3,then i change the original ab3100 back same problem
any help ?please?
or someone expert told me what is the problem with the new ab3100 power ic ? it is need program ? ihave try over 5pcs
Old 04-23-2009, 06:30   #2
ahhongchai
Member: 68833
no one face this problem ??
Old 04-25-2009, 06:03   #3
ahhongchai
Member: 68833
update .........
ab3100 today arrive but no result , phone cant on and cant flash after change power
Old 05-13-2009, 08:51   #4
ahhongchai
Member: 68833
no way to program a ab3100 ?
Old 06-12-2009, 14:21   #5
samshl
Member: 74308
i face this problem also
change a new power ic already same hot power ic
Old 07-04-2009, 19:31   #6
axel80
Member: 333017
not yet public available, but will work fine with empty AB3100 and IMEI show some zeros
29.06.2009 13:44:41 SIGNED MODE (USING SERVER)
29.06.2009 13:44:41 ALTERNATIVE SECURITY BYPASS ENABLED
29.06.2009 13:44:41 PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
29.06.2009 13:44:41 CFG:101001100100000
29.06.2009 13:44:53 ChipID:C802,EMP protocol:0401
29.06.2009 13:44:53 BOOTROM MODE DETECTED
29.06.2009 13:44:57 OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
29.06.2009 13:45:00 LDR:2009-04-21 18:16 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A081
29.06.2009 13:45:00 DEVICE KEY:91A9D0D66EB9B33370584CC3CDB70336 (2)
29.06.2009 13:45:01 LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081
29.06.2009 13:45:01 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081
29.06.2009 13:45:04 GOT SEED:B3F92E0C0000000000000000
29.06.2009 13:45:04 P96 AUTH PASSED
29.06.2009 13:45:04 RESETTING SECURITY TO FACTORY STATE...
29.06.2009 13:45:05 RESTARTING...
29.06.2009 13:45:05 PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
29.06.2009 13:45:08 ChipID:C802,EMP protocol:0401
29.06.2009 13:45:08 BOOTROM MODE DETECTED
29.06.2009 13:45:09 unexpected PDU:060115
29.06.2009 13:45:11 OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
29.06.2009 13:45:12 LDR:2009-04-21 18:15 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A081
29.06.2009 13:45:13 LDR:2009-04-21 18:16 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A081
29.06.2009 13:45:13 WRITING SEMCBOOT...
29.06.2009 13:45:17 PREPARING SECURITY...
29.06.2009 13:45:17 WRITING CLEAR SIMLOCK UNITS...
29.06.2009 13:45:19 ALL UNLOCK/LOCK CODES SET TO "36570247"
29.06.2009 13:45:21 CHANGING DOMAIN TO "CURRENT"
29.06.2009 13:45:21 SIGNING...
29.06.2009 13:45:26 DEVICE KEY RESTORED
29.06.2009 13:45:27 writing "C:\setool2g\gdfs_in_ssw_format\A2\K850\Sofia_TA.ssw"
29.06.2009 13:45:28 ALLOWED DOMAINS:BLUE BROWN
29.06.2009 13:45:28 MAXIMUM CID:110
29.06.2009 13:45:28 Will flash 12 blocks...
29.06.2009 13:45:34 ssw file accepted
29.06.2009 13:45:35 Phone detached
29.06.2009 13:45:35 Elapsed: 54 secs.
29.06.2009 13:46:05 SIGNED MODE (USING SERVER)
29.06.2009 13:46:05 CFG:100010000000000
29.06.2009 13:46:22 ChipID:C802,EMP protocol:0401
29.06.2009 13:46:22
29.06.2009 13:46:22 PHONE STATE: "FACTORY"
29.06.2009 13:46:22 SUPPORTED FLASH CID IS NOT DETECTED [0000]
29.06.2009 13:46:24 OTP LOCKED:0 CID:00 PAF:0 IMEI:EMPTYBOARD CERT:BROWN
29.06.2009 13:46:25 LDR:2009-04-21 18:15 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A081
29.06.2009 13:46:25 LDR CAPS:SYSTEM FLASH SIGNATURE
29.06.2009 13:46:27 LDR:2009-04-21 18:12 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A081
29.06.2009 13:46:27 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
29.06.2009 13:46:27 writing "D:\!SETOOL\K850\R1FA035_APP_SW_1200_4400_GENERIC_SO_REDBROWNBLUE_CID52_49_DB3150.software"
29.06.2009 13:46:39 ALLOWED DOMAINS:BLUE BROWN RED
29.06.2009 13:46:39 MAXIMUM CID:52
29.06.2009 13:46:39 Will flash 701 blocks...
29.06.2009 13:52:24 ssw file accepted
29.06.2009 13:52:24 writing "D:\!SETOOL\K850\R1FA035_FS_S_ASIA_LEVAN_SO_REDBROWNBLUE_CID52_49.software"
29.06.2009 13:52:30 ALLOWED DOMAINS:BLUE BROWN RED
29.06.2009 13:52:30 MAXIMUM CID:52
29.06.2009 13:52:30 Will flash 465 blocks...
29.06.2009 13:56:18 ssw file accepted
29.06.2009 13:56:28 using GENERIC phone customization
29.06.2009 13:56:28 tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm
29.06.2009 13:56:29 tpa/preset/custom/FM_PICTURES_HOOK_3.itm
29.06.2009 13:56:29 tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
29.06.2009 13:56:29 tpa/preset/custom/FM_THEMES_HOOK_3.itm
29.06.2009 13:56:30 tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
29.06.2009 13:56:30 tpa/preset/custom/GAMES_HOOK_3.itm
29.06.2009 13:56:30 tpa/preset/custom/MC_MUSIC_HOOK_3.itm
29.06.2009 13:56:31 tpa/preset/custom/MC_PHOTO_HOOK_3.itm
29.06.2009 13:56:32 tpa/preset/custom/MC_VIDEO_HOOK_3.itm
29.06.2009 13:56:32 tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm
29.06.2009 13:56:32 tpa/preset/custom/preloaded_config.xml
29.06.2009 13:56:35 tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm
29.06.2009 13:56:35 tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm
29.06.2009 13:56:35 tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm
29.06.2009 13:56:36 tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm
29.06.2009 13:56:36 tpa/preset/custom/Customize.xml
29.06.2009 13:56:37 Phone detached
29.06.2009 13:56:39 Elapsed: 634 secs.
29.06.2009 18:09:56 SIGNED MODE (USING SERVER)
29.06.2009 18:09:56 ALTERNATIVE SECURITY BYPASS ENABLED
29.06.2009 18:09:56 PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
29.06.2009 18:09:56 CFG:101000000100000
29.06.2009 18:11:33 ChipID:C802,EMP protocol:0401
29.06.2009 18:11:33 BOOTROM MODE DETECTED
29.06.2009 18:11:36 OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
29.06.2009 18:11:39 LDR:2009-04-21 18:16 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A081
29.06.2009 18:11:39 DEVICE KEY:91A9D0D66EB9B33370584CC3CDB70336 (2)
29.06.2009 18:11:40 LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081
29.06.2009 18:11:41 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081
29.06.2009 18:11:43 GOT SEED:5DA568500000000000000000
29.06.2009 18:11:43 P96 AUTH PASSED
29.06.2009 18:11:43 RESETTING SECURITY TO FACTORY STATE...
29.06.2009 18:11:44 RESTARTING...
29.06.2009 18:11:44 PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
29.06.2009 18:11:47 ChipID:C802,EMP protocol:0401
29.06.2009 18:11:47 BOOTROM MODE DETECTED
29.06.2009 18:11:47 unexpected PDU:060115
29.06.2009 18:11:49 OTP LOCKED:0 CID:00 PAF:0 IMEI:00000000000000 CERT:BROWN
29.06.2009 18:11:50 LDR:2009-04-21 18:15 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A081
29.06.2009 18:11:51 LDR:2009-04-21 18:16 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A081
29.06.2009 18:11:51 WRITING SEMCBOOT...
29.06.2009 18:11:55 PREPARING SECURITY...
29.06.2009 18:11:55 WRITING CLEAR SIMLOCK UNITS...
29.06.2009 18:11:57 ALL UNLOCK/LOCK CODES SET TO "27700747"
29.06.2009 18:11:59 CHANGING DOMAIN TO "CURRENT"
29.06.2009 18:11:59 SIGNING...
29.06.2009 18:12:04 DEVICE KEY RESTORED
29.06.2009 18:12:05 Unlock DONE
29.06.2009 18:12:05 Elapsed: 128 secs.
Old 07-04-2009, 19:42   #7
axel80
Member: 333017
update .........
phone must be in BOOTROM MODE
Old 11-08-2009, 09:50   #8
atash_e_zohoor
Member: 375784
Sonork: 100.112240
Hi sir the_laser
plz help me
after change AB3100 Ic
and Unlock that
Loaded 51 flash descriptors
CFG:10100000000000
ChipID:E900,EMP protocol:0401
A2ROM_loader_on_loader:hdr err:0004,1
A2ROM_loader_on_loader:err details:06020302160217022C01020208
A2ROM_loader_on_loader:bad result [00/FF]
can't load ACCESS CPU preloader
FAILED TO SETUP PHONE
Elapsed: 170 secs.
Old 11-09-2009, 08:03   #9
arrow1339
Member: 1024750
OK since i search and search, i found setool is able to repair A2 GDFS, change power asic, change new flash chip.
Today, i posted here is to share with members who still doesn't understand what? where? when?
Go to SEMC A2
- Select T700
- ECC mode (NONE)
- Set DOMAIN to (BROWN) - for some older SETool version is shown (R&D)
Go to Settings
- Tick (Signed Mode)
- Tick (Enable Alternative Security Bypass)
Go to SEMC A2
- Press (Unlock/Repair)
- Add (Shinobu_TA.ssw)
- Press (Flash)
- Remove (Shinobu_TA.ssw)
- Add main, fs and custpack [if you don't have custpack, just add a tick (Complete Phone After Flash) in Settings
- Press (Flash)
Your phone should have to complete flashing like normal phone, after flashing continue here.
- Remove Main, Fs and Custpack
- Load T700_GDFs.zip in Misc
- Press (Write GDFS)
- Remove T700_GDFS.zip
- Set DOMAIN to (RED)
Note: T700, Shinobu_TA.ssw, T700_GDFS.zip are just an example.
Some useful information.
RED = RETAIL
BROWN = R&D
BLUE = FACTORY
Shiho_TA.ssw - For C905
Sofia_TA.ssw - For K850
Jie_TA.ssw - For K630, K660 & V640
Shinobu_TA.ssw - For W910 and other A2 phone.
Page generated in 0.09692 seconds with 8 queries
