Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-23-2010, 01:20   #1 (permalink)
::.::RAMJAN::.::'s Avatar
Member: 258172
Thanks Meter: 10,367
How to enter Unlock Code on BlackBerry Phones? [ONLY HERE]
How to enter Unlock Code on BlackBerry Phones, ONLY HERE
All other threads about same topic will be deleted without warning !
Model : BlackBerry 8700
Go to the Menu -> Options -> Advanced Options -> Sim card press select, while holding the Shift key (bottom right corner CAPS), type mepd. You should now see the five locking categories listed, while holding the alt key, type mep2. Release the alt key. You are now prompted to enter the Network MEP code. Enter the code, enter Return/Enter, the device should then be unlocked.
Model : BlackBerry 8800
You must have a SIM card in your phone to complete these steps ( Can be active or inactive )
1 - Go to settings menu => and then Options
2 - Select Advanced options => and then Sim card
3 - Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
4 - Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
5 - You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code received from UnlockBase.com and press in the track wheel / jog dial to confirm
6 - Your phone is now unlocked
Model : 9500/9530 Series
Ensure the SIM Card that came pre-installed in the 9530 is inserted.
Go to 'Manage Connections'
Click on 'Turn All Connections Off'
Go to 'Options'
Click on 'Status'
Go back to 'Options'
Click on 'Advanced Options'
Click on 'SIM Card'
Type 'MEPD' (letters will not appear on-screen but a menu will pop up)
Type 'MEP2' (user will be prompted to enter MEP code)
Enter the unlock code
Reboot device
Click on 'Restore Connections'
Device is now unlocked
Please note when entering MEPD, ETC. You need to use caps.
Model : BlackBerry 8220
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (where needed)
7. Type MEPPD or MEPD (you will not be able to see the typed info)
8. Enter MEP2 or MEPP2
9. Now it will say enter network mep code
Model : BlackBerry 8100 Pearl
1 - Go to Options Menu => Advanced Options
2 - In the SIM Card menu, hold down the shift (right of the zero, cap) press meppd
3 - You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2
4 - Enter the unlock code.
Model : BlackBerry 8100 (Vodafone Australia)
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only using SIM cards from Vodafone Australia. In case of difficulties, please refer to the FAQ listed below
1. Take note of the unlocking code shown above
2. Insert a Non-Vodafone Australia working SIM card.
3. Ensure the phone is charged and then switch the phone on.
4. Optional Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5. The phone will then display a message. The most common is ?nvalid SIM card? (Different message? See FAQ below)
6. Select ?urn Wireless Off?
7. Select ?ettings?Menu , then go to Advanced Options > SIM Card
8. Type alt-MEPT by holding the ALT-key and typing the letters MEPT with multitap i.e. type hold ALT, type {M}{ER}{OP}{OP}{TY}
9. When prompted with ?nter Network MEP code (255 left)?on the screen, enter the 16-digit network unlock code provided for your phone, then press Enter. (Unlocking code is shown above)
10. Reset the phone by pulling the battery
11. Switch the phone on and the handset will be unlocked automatically. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
FAQ:
Question: My phone asks to enter a PIN number
Answer: For SIM cards with PIN ENBLED you will be required to enter a PIN. This is not the unlocking code that has just been provided. For information concerning the PIN, PIN2, PUK and PUK2 codes for a SIM card please read the manual that came with your phone. This is not a handset unlocking difficulty.
Question: My handset displays a different message then what is shown in this procedure when I insert a Non Vodafone Australia SIM card.
Answer: The most common message the phone will display is ?nvalid SIM card? Because each handset may have a different variation in software there is no common message. If your handset displays a different message it is recommended to move onto the next step. Note: Faulty SIM Cards - The handset may also display messages indicating the SIM you are using to unlock the handset is faulty, it could display ?nsert SIM??ad Card? ?ard Error?or ?ard Rejected? confirm the SIM card is inserted correctly ?Gold area downwards and the cut of the corner matches correctly. You will need a working Non Vodafone SIM card to unlock the handset, Vodafone can not assists with other networks faulty SIMs.
Question: I am outside of Australia and experiencing difficulties unlocking the phone that I purchased from a Vodafone Australia outlet
Answer: Clearly note this in the difficulties description. Vodafone Australia can only send a reply to the difficulty by email.
Model : All BlackBerry
1 - Using the menu go to Settings Menu -> SIM card pressselect.
2 - While holding the SHIFT key, type mepd
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type mep2.
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
NOTE : please keep this thread clean out of thanks posts & good work posts , only for How to enter Unlock Code on BlackBerry. Thread started as to clean mess from BB Faq
Best Regards
::.::RAMJAN::.::
The Following 55 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 02-27-2010, 09:56   #2 (permalink)
recallrules's Avatar
Member: 433173
Sonork: 100.1590587
Thanks Meter: 31
and if it has " Enter network MEP code (0 left):" then?? what will,be the sol? how do v reset it?
regards
The Following User Says Thank You to recallrules For This Useful Post:
Old 02-27-2010, 10:08   #3 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Arrow
regards
Whats ur device ? if 7xxx then u can reset counter using rom booter
and its not work on 8XXX and higher
Delower
The Following User Says Thank You to delower10 For This Useful Post:
Old 02-27-2010, 13:56   #4 (permalink)
Member: 433173
Sonork: 100.1590587
Thanks Meter: 31
its blackberry 8900 javelin
Old 02-27-2010, 14:34   #5 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,429
Sorry to say no other solution, only DM3 can recover this type problem
Delower
Old 03-03-2010, 05:13   #6 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
blackberry 9530 unlock broblem help
i have balckberry 9530 unlock but i tried so many time it is not become enter mep code because personalization sim disabled ok
then netwok inactive it is my problem for not become enter mep code
Old 05-04-2010, 18:00   #7 (permalink)
kriptikchicken's Avatar
Member: 933132
Thanks Meter: 147
If it says 'Network INACTIVE' on any Storm 1 or 2, then it is unlocked.
Old 05-04-2010, 18:03   #8 (permalink)
hajji1's Avatar
Member: 212683
Thanks Meter: 115
I have bb 8310( reset password tried 10 time set automatically formated all data delete ) now when I open its searching long time .( vodafone uk)
how to solve this problem
Old 05-25-2010, 17:58   #9 (permalink)
Member: 1310710
Sonork: 9890
when i run mfi multiloader , a message shows something like this ,cant load boot images
can anyone help me 4 this
Old 05-26-2010, 07:58   #10 (permalink)
Member: 757799
Thanks Meter: 782
how about 8300 cannot go to mep2
Old 05-26-2010, 08:16   #11 (permalink)
Member: 258172
Hold the ALT Key while typing mep2.
The Following User Says Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 05-26-2010, 08:27   #12 (permalink)
Member: 757799
Thanks Meter: 782
how about this sir................
The Following User Says Thank You to trio1 For This Useful Post:
Old 06-24-2010, 06:50   #13 (permalink)
Member: 589712
Thanks Meter: 82
how about 8520 ?
Old 06-24-2010, 06:57   #14 (permalink)
Member: 265104
Sonork: 100.1609402
Thanks Meter: 88
How to enter Blackberry unlock codes
The Following User Says Thank You to tanha For This Useful Post:
Old 06-26-2010, 19:17   #15 (permalink)
Member: 1184555
Sonork: dapson001i
How do i remove activation required on black berry screen and put my phone number on it?
The Following User Says Thank You to dapson001i For This Useful Post:
How to Enter Unlock Codes on BlackBerry (If you get unlock code) ..::GsmEasy::.. BlackBerry (RIM) 13 11-05-2010 12:32
how to enter unlock code on blackberry 9000 bold lifeng1205 Gsmfather The Wholesale Unlocking Database 3 11-05-2009 12:37
[FAQ] Code by IMEI : How to enter Unlocking Code on my Mobile Phone ? UnlockBase.com UnlockBase 93 08-06-2008 14:59
Please verify how to enter unlock code on this phone... sdimitris Gsmfather The Wholesale Unlocking Database 2 05-09-2008 06:09
Page generated in 0.24131 seconds with 9 queries
