Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > BF, BG, TH, BHx Series
BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here.
View Poll Results: tested on the folowing and work 100%
BF3 11 55.00%
BF4 4 20.00%
BF5 3 15.00%
BG3 11 55.00%
Multiple Choice Poll. Voters: 20. You may not vote on this poll
Old 01-12-2004, 00:39   #1 (permalink)
Member: 41449
Thanks Meter: 4
Exclamation Unlock all Alcatel BF BG even unsupported versions for free
This tutorial shows you how to unlock all Alcatel BF or BG or new models for free, without using expensive soft like wray's or magician or.. you'll need only hexworkshop and a free soft to read and write flash of your mobile, like s2gsm patched by the great SPUNLOCK, you can find it at;
The first gift by Spunlock
the second
the third .. you will need also to use your brain :-)
dedicated to people at gsm4arab.net especially to khalil -the great moderator- and all of you seekers for free unlocking :-)
THE INDEX;
1 :: Reading the flash from phone
2 :: Finding the appropriate block
3 :: Unlocking the plash – creating own partial
4 :: Writing the flash to mobile
5 :: Extra
let's say you got an new mobile phone with new firmware version for example BG3 525 ver 106 KI127, this version is not yet supported even with new $$$ unlocking soft :-). To read the flash , use henrich 1.82 soft, check first that it recognize flash type –amd or Thomson or..- if not use free soft like s2gsm to read the flash. For cable you can find it from many sites , me I work with self made cable once you read full flash check if it is (correctly read by looking to the size of file ex: 2MB or 4MB) then make 2 copies of that flash (for safety reasons)
Now open your eyes ! !
The block is a set of data (64Kb) inside the flash for example the block
In a 2 MB flash would start from this address 00060000 and ends at 0006FFFF . To find the correct block open the copy of your flash with hexworkshop and search for this hex string 8009022802 if you get only one instance as a result, then you found the block, if more than one, write down the address where you encountered other instances. To verify that the block is correct search for this 2nd Hex string F0B5061C151C0C1C1F1C note down the address where it is found and repeat the same steps for this last hex string B00D1C1E1C .
Now you got a map of the flash, just compare the results you got and surely you will find the correct block( the correct block is the one that contains all the 3 Hex strings, or at least 2 of them)
3 :: Unlocking the flash – creating own partial
well now you got 2 options either unlock the block and save it separately so that whenever you got the same phone version you write it directly by henrich (warning!!; check always if the soft support reading and writing block correctly) or you unlock the flash then upload it to your phone.
Anyway copy to a new file the full block so as to make your job more easier when trying to edit the locks.
Here's how you unlock; Alcatel made 3 levels/locks in locking their phones, to unlock them you must replace their data with this:
1; 0020F746
2; 0020F746
3; 0120
To disable the 3rd lock level search for 8009022802 and replace 0228 by 0120 (note that 0228 may be different but it's always betwen 8009XXXX02).
Now we will disable the first lock level, search for F0B5061C and replace it with 0020F746,if you find more than 1 instance, look at the one that is same as picture 1 ( you may notice the repetition of 1Cxx 1Cxx 1Cxx )
We still have to desable the 2nd lock level, so search for B00D1C1E1C and replace 0D1C1E1C by 0020F746 (note that 0D1C1E1C may be a little bit different from one phone to another, but it's always after B0xxxxxxxx) .
Check this pictures;
1
2
3
now you successfully unlocked your flash, but always check if it's correct before writ. If you find the solution to one version then save the addresses for future use, so that you will not need to redo the whole work next time, because the addresses vary only from on version to another. To help you more, check the list of the locked blocks for different versions here .
write the new unlocked flash by the software used before to read it from phone but check always whether it is correctly read , else you get damaged phone for ever ! ! and don't tell me that I didn't warn you.
I used this method to unlock this versions;
And they all work 100% .
5 :: Extra
if you can't do this, just contact me here and I'll do it at your place for freeeeeeeee .
with my great regards Idrissi Abdessamad… good luck !
PS; if you get problems to view pictures or whatever just download the full tutorial heeeere
Old 01-12-2004, 02:30   #2 (permalink)
simpa's Avatar
Member: 45476
Thanks Meter: 16
wow
GREAT
thx
Old 01-12-2004, 07:26   #3 (permalink)
Member: 1233
Thanks Meter: 2
Unlocked partials are only one problem. The other problem is writing this partials in phone due to a different flash types. Do you have soft that can write in ST flash (ID:20D1)?
Regards
Old 01-12-2004, 13:09   #4 (permalink)
Member: 41449
Thanks Meter: 4
@pavlin
well if you cant writ diret partial to phone; unlock the correct partial inside the whol flash then upload it to phone..
for new flash models use s2gsm software
Old 01-12-2004, 15:21   #5 (permalink)
Member: 41449
Thanks Meter: 4
also download new partials in the group ! !
Old 01-12-2004, 15:21   #6 (permalink)
Member: 41449
Thanks Meter: 4
Old 01-13-2004, 13:07   #7 (permalink)
Bomber's Avatar
Member: 1756
Thanks Meter: 9
thanx for this interresting informations
i've read a full flash with bg3 flash reader by bekosbrothers but the flash type is unknown, but the flash which i've read seems to be correct comparing with other flash files
can i unlock the flash & upload it again to phone without risk ? or i'll have a dead phone forever ?
thanx
Old 01-13-2004, 13:34   #8 (permalink)
ZXR
Member: 14778
That's my problem, too.
There ist still no free Soft, that can write in these special flash types...
If there is one, tell us please !
Old 01-13-2004, 13:38   #9 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
another idea
Hi Mates!
Yes this solution works... i tested it... Great...
BUT...
I think this solution is a kinda slow one, whit flashin progress also more slower...
It would be great if anobody who have knowlege about programing to write an auto patcher because as i can see, it can be automated as well...
in this case there is three step:
1. Flash reading
2. patching
3. flash writing
Its just an idea...
Think about it..
WBR
DaZe
Old 01-13-2004, 21:29   #10 (permalink)
Member: 41449
Thanks Meter: 4
@boomer
try using s2gsm soft, the full one it works.
@dazexy
i'm thinking of that too, just as the slide show editor for nokia phones..
Old 01-14-2004, 02:01   #11 (permalink)
DEBLOQUETOUT's Avatar
Member: 25342
Thanks Meter: 38
good information
Old 01-15-2004, 00:10   #12 (permalink)
foufou's Avatar
Member: 18703
Thanks Meter: 330
Originally posted by numediaweb
@boomer
@dazexy
good work "idrissi"
Old 01-15-2004, 09:04   #13 (permalink)
Bomber's Avatar
Member: 1756
Thanks Meter: 9
s2gsm full one ?, can some one post a link plz ?
Old 01-15-2004, 09:27   #14 (permalink)
Member: 8696
Thanks Meter: 45
http://www.s2gsm.com/
Old 01-15-2004, 11:17   #15 (permalink)
ADD-GSM's Avatar
Member: 16077
Re: Unlock all Alcatel BF BG even unsupported versions for free
there soft is not there
all unsupported version for new and old LG... chimed09 Easy-Unlocker 1 12-28-2008 16:16
New software version Alcatel BF-BG-BH UNLOCKER/FLASHER v2.34 Gobi VygisToolbox 3 11-30-2004 21:44
alcatel bf, bg, bh, henrich v4.3 cracker lzinn BF, BG, TH, BHx Series 0 10-13-2004 19:03
Wanted - Alcatel BF/BG/BH flasher - unlocker v2.01 gsmcaptain Wanted Products 0 12-12-2003 18:35
All Alcatel BF, BE Service Software !!! NEW ! sixkiller666 Main Sales Section 0 04-24-2002 21:22
Page generated in 0.25884 seconds with 10 queries
