Old 10-07-2003, 19:36   #1
Phantasm4489
Member: 40901
1.4.2.10 Hack
The security seems to have been modified in the 1.4.2.10 drivers, btsec.dll
doesnt seem to be used anymore and the security is present in these 3 files
BTTray.exe (typically in c:\program files\widcomm)
BTStackServer.exe (lives in the same directory as BTTray.exe)
WBTAPI.DLL (lives in c:\windows\system32 or c:\winnt\system32)
To hack the 1.4.2.10 widcomm drivers search for this hex string
83 C4 04 85 F6 0F 85 07 01 00 00
and if X is the address at which the first byte of this string resides then edit the following locations:
X+5, Old value = 0F 85 07 01 00 00, new value = 90 90 90 90 90 90
X+29, Old value = 0F 85 EF 00 00 00, new value = 90 90 90 90 90 90
X+48, Old Value = 0F 84 Dc 00 00 00, new value = 90 90 90 90 90 90
make the same changes to all 3 files.
When I tried this I was able to get the drivers to start up successfully, but I cant fully
test them as the only BT hardware I have is the MS keyboard and mouse, and it seems like they
might have broken the HID service in this version of the drivers (or maybe its the crack but
I dont think so).
Thanks should go to the person who created the 1.4.1 crack, as this one is mostly based on that.
Old 10-07-2003, 19:55   #2
zfrank
Administrator
zfrank's Avatar
Member: 3
Sonork: 100.44530
cool
thx for sharing this info
Old 10-08-2003, 15:10   #3
martroy
Member: 41137
Question
Thanks Phantasm4489!
I tried it last night and no luck with my Belkin dongle. It fixes the license issue but now, when I try to Find Bluetooth Devices from My Bluetooth Places, I get the following error message "No local Bluetooth device was detected". The dongle seems to be recognized since the tray icon changes from red to white when I plug it. I can also see the device properties from the Hardware tab in the Advanced configuration.
I'm able to discover/pair from my phone but not the other way around...
Anybody has the same problem?
Martin
Old 10-08-2003, 19:23   #4
gorgoroth
Member: 39992
I have the same problem. The detection is not working. Maybe we can edit the bluetooth database manualy, but i cannot find where it is.
This is a problem when the device cannot initiate the connection (like a headset)
btrez.dll in system32 folder is the file involved, but I couldn't find the hex squence
Old 10-09-2003, 09:45   #5
MaikS
Member: 35736
Maik
Old 10-12-2003, 02:48   #6
Phantasm4489
Member: 40901
Sorry for the false start guys, but i am pretty sure ive got this working now.
Ignore the changes above and make these changes to the same three files instead:
search for 83C40885F60f85ef000000 and replace 0f85ef000000 in the sequence with 909090909090
search for 8bf083c4083bf7750e3bef750a and replace 750e with 9090 and 750a with 9090
Using this crack ive managed to get my new phone and my microsoft bluetooth mouse work quite nicely with the microsoft dongle.
I used the belkin drivers, but it should work for others too.
The Following User Says Thank You to Phantasm4489 For This Useful Post:
Old 10-12-2003, 16:45   #7
bluetoothmaster
Member: 35694
@Phantasm4489
good work
it´s working perfect
again new work for widcomm
with 1.4.2.x-version btsec.dll is more secure, but widcomm forget secure also all exe
btw, not working with evox 1.4.2.10, there are some more changes.., with belkin no problem ;
Old 10-12-2003, 17:29   #8
gorgoroth
Member: 39992
Thanks Phantasm,
This is working perfectly on berklin drivers and Dlink DBT120. At last, after 2 month, I can use my bluetooth adapter on my Windows 2003 computer.
It's funny we still need to crack something that should be available with any adapter...
Old 10-13-2003, 00:15   #9
Phantasm4489
Member: 40901
So what was the problem with the EvoX drivers, you couldnt find the hex bytes? or just not working after changing those bytes?
In what way was it not working?
Old 10-13-2003, 08:37   #10
bluetoothmaster
Member: 35694
I looked today again. Only small changes
in epox in second hex-strings 3 bytes are different
8BF083C40C3BF5750E3BFD750A
maybe someone can test epox-software
http://www.epox.de/dl/techsupp/BTW_1_4_2_10.zip
Old 10-13-2003, 12:12   #11
Quank
Member: 41492
This patch work with BTW v. 1.4.2.10 service pack 4!
BTW from http://www.mavintec.com/download/usb.zip work fine with my Tecom BT3030
Thanks Phantasm4489! & bluetoothmaster!
Old 10-13-2003, 22:00   #12
Garry_Whole
Member: 41545
Unfortunately MSI USB Dongle does not work, does not see other devices. I tried different versions of drivers 1.4.2.10 - any effect.
Phantasm4489 has described hack for the version of drivers SP3, but Quank speaks about version SP4 where there is other line about which speaks Bluetoothmaster.
As a result of it turns out nothing. Can be eat other variant with version SP4?
Old 10-13-2003, 22:17   #13
Phantasm4489
Member: 40901
please be more specific as to exactly how it isnt working. Is it the bluetooth dongle that it doesnt recognise or are we talking about it not being able to discover your bluetooth devices? What happens if you try to discover the other way around?
Old 10-14-2003, 09:23   #14
theh0g
Member: 41583
Dude, I have a MSI and it works, but not on Belkin. Use Anycom drivers and edit it like Phantasm said. For link to the driver, search this forum. My MSI's dongle works fine now, finds the phone, transfers files, ...
Old 10-14-2003, 11:27   #15
blueflame
Member: 41568
Thanks Phantasm. On Windows XP, the Belkin drivers able to pair up my Microsoft BT adapter to my Microsoft BT mouse, SE T610 and HP 2210.
But one question though... are you still able to customize your BT mouse's thumb buttons and also the accelerated scrolling? Mine switched back to the default Forward and Back. I know this may sound quite petty when other people are having difficulty getting their BT to work. But I will appreciate it if you could look into this when you have the time. Thanks.
[IMG] code is Off
Page generated in 0.12854 seconds with 6 queries
