Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Samsung > Samsung Wallpapers,Ringtones
Samsung Wallpapers,Ringtones Only Ringtones, Wallpaper and other media Files.
Old 11-10-2003, 07:44   #1
Megalin
Member: 43365
Uploading RIngtones & Pics to C100
Hi
I have tried EasyStudio and EasyGPRS 2.1.6 and they all don't work. I can edit my phone book but i can not upload images or ringtones to my phone, its says "failed to send". Pls HELP I am getting frustrated!!!!!!!!!!!!!!!!
Thanks
Old 11-10-2003, 09:55   #2
Moosani
Moosani's Avatar
Member: 15866
Sonork: 100.109690
used infra red device check working or not
then active infra red in modile then put the mobile in the range of
infra red the run easy gprs 2.1.6
they will detect your mobile automatic
and then use melody to mobile option and image to mobile etc.
thanks and regards
Old 11-10-2003, 09:59   #3
Megalin
Member: 43365
I tried it but it still doesn't work
thanks
Old 11-10-2003, 14:11   #4
mujie
mujie's Avatar
Member: 8304
CHECK YOU IRDA DRIVERS,MAYBE NOT INSTALLED CORRECTLY
Old 11-10-2003, 14:14   #5
Megalin
Member: 43365
Hi
the program reads my phonebook and messages but I can't upload pic or ringtones, that is my problem. I do all of this thru IR
Old 11-10-2003, 14:58   #6
MobileSoft
MobileSoft's Avatar
Member: 3355
hi, I had same problem initially, but found out that if you do the following it works. with regards to pictures:
convert all you pictures using a graphics editor to the following specs:
1.) 128 x 97 pixels
2.) change colour depth to 256 colors
3.) save image as a .bmp file
4.) make sure that the saved .bmp does NOT have RLE compression.
This should sort your problem out.
With regards to the ringtones, there is an application that converts .mid file to a compatible format for use with EasyGPRS. Search for in on Google, cos I cant remeber what is was called!
Hope this helps u
Good Luck
Old 11-10-2003, 16:06   #7
Yashaka
Yashaka's Avatar
Member: 30124
hi
i want to upload the picturs in my c100 mobile
pls provide me the software to use with IR
contact me at: yashaka@mail15.com
10x
Old 11-10-2003, 17:05   #8
squirrel
Member: 43472
You can use EasyGPRS 2.1.6 (or 2.1.2) provided by Samsung (you can get it from www.samsungmobile.com)
At first, you should check if ur IrDA cable was connected and installed correctly (WinXP will automatically detect ur device, but the others like Win98, WinME and even Win2K don't)
Then, you have to install EasyGPRS software and active ur phone's IrDA port (Menu-4-1)
After that, you can start EasyGPRS, it will automatically load ur phone book, SMS, call record... Use MelodyToPhone to upload ringtones and ImageToPhone to upload images.
Ur image can be .GIF, .JPEG or .BMP format (I usually use .JPEG)
I think you don't need to change color depth to 256, it works well with .JPEG but with some animated .GIF, it can't (maybe image's size is a little big)
Old 11-11-2003, 06:25   #9
Megalin
Member: 43365
HI
I have tried everthing but it still gives me an error. Can I use the cable supplied with LG G7100, they fit perfectly? I feel like i have hit a dead end with this issue
Old 11-11-2003, 09:42   #10
mujie
mujie's Avatar
Member: 8304
Originally posted by Megalin
HI
DONT DO THIS,WILL NOT WORK.SAMSUNG HAS NOT DESIGNED THE C100 CABLE YET DUE TO THE LOW DEMAND.TRY AN IRDA ON OTHER PC.MAYBE IT WILL WORK
Old 11-11-2003, 09:44   #11
Megalin
Member: 43365
Hi I have tried Irda too but it still gives me the same error
Old 11-14-2003, 16:40   #12
squirrel
Member: 43472
Maybe there are problems with ur IrDA cable, ur PC or ur handphone. Go to nearest Samsung support center to figure out what's wrong...
In Samsung support center, there are usually some PC with recharge cable and IrDa cable... You can go there and use for free! :-)
Good luck to all :-)
Old 11-15-2003, 08:14   #13
dulls
Member: 35466
I am using EasyGPRS software for my C100. It is working fine, I can upload Pics and Tones as well.
Regards,
dulls
Old 11-19-2003, 19:57   #14
squirrel
Member: 43472
Uploading is okie now, so why don't we talk about polyphonic ringtone for Samsung...
I'm wondering if the sound card has any affect on converting .mid into .mmf... (by PSM or something like that) I think it does!
Can anybody tell me about that?
Old 11-20-2003, 15:09   #15
artika
Member: 30202
I upload Pics and Tones to C100 with cable.Using EasyGPRS software.Work fine!
Page generated in 0.09735 seconds with 6 queries
