Old 11-12-2003, 10:53   #1
DinkTooth
Member: 43900
Question BT Mobile and VoIP
Hi All,
I am pretty new to bluetooth, but have been monitoring this forum to get some tips. So far it has been very useful .
Basically what I would like to do is to use my mobile as a 'handset' for VoIP calls. In my mind this means it effectively becoming the speakers and mic to my broadbanded notebook. Note that I do not have a BT headset, but I suppose that I want to use my T610 for this purpose.
My setup is as follows: -
XP Pro (SP1) Notebook
Vaio BT Dongle (CSR firmware 355 I think)
Widcomm 1.4.2.10 (thanks to this forum )
SE T610
The widcomm stack installed without issue, recognises my dongle and appears to be working. Pairing of devices works in both directions without issue.
However when I initiate the audio gateway on the notebook, a connection is made to the phone, which then displays 'after the tone say the voice command' > 'no match' > BT connection dropped.
I'm not sure if this is the right way round but wanted to try it anyway. I was wondering if anyone has tried this or similar and can suggest a few tips/tests to try out mainly for VoIP but eventually more advanced notebook remote control.
Thanks in advance.
Old 11-12-2003, 15:59   #2
Phantasm4489
Member: 40901
I could be wrong but i dont think you can do this. It would mean that your phone would have to support the headset profile. I think the audio gateway is purely for sending audio to another bluetooth device (although I have to admit, ive not really played with the audio gateway stuff - or the headset stuff much).
Old 11-12-2003, 16:13   #3
DinkTooth
Member: 43900
Just looking down the list of supported profiles on the SE T610, it shows the headset profile (not the audio gateway).
Old 11-12-2003, 16:17   #4
DinkTooth
Member: 43900
Do you think it's worthwhile posting my request to the geekzone forum? They seem to have played around with these profiles and I noticed you are a member there.
Old 11-12-2003, 16:28   #5
Phantasm4489
Member: 40901
ah well... as I said, I could easily be wrong. Posting the question on geekzone is probably a good idea.
Old 11-12-2003, 16:45   #6
DinkTooth
Member: 43900
Cool... I've posted to geekzone. If I hear anything useful (either way), I'll post back here as well.
Old 11-18-2003, 11:16   #7
DinkTooth
Member: 43900
Unhappy
Bump... anyone?
Old 11-18-2003, 15:27   #8
kewl
Member: 44321
Hi DinkTooth,
I hv a SE T610 and the Tecom BT3030 and Iv also
tried the audio gateway / headset feature without
success.
Please do post if you find any info.
Thnx in advance.
Old 11-18-2003, 21:56   #9
sagarka
Member: 26606
i have tried for this but i can do it with some limitation if u have need more help u can asked me at gm_mobile@hotmail.com
i have make my own bt network with p800 and make call via my network but for more experment i wil have to need alot of time and i 2500ser cisco router
Old 07-11-2009, 00:13   #10
Livvy Pene
Member: 1071928
Mobile broadband will not be fast enough to process the data exchange for Voip. You will suffer continual broken links and time lag. Also you will very quickly exceed your cap because of the amount of data exchanged.
You might just as well make a mobile phone call because it will still cost you the same without the aggro. The idea of Voip was for fixed line or cable broadband to make free calls!voip softphone
[IMG] code is Off
Page generated in 0.10232 seconds with 6 queries
