Member: 38666 Status: Offline Thanks: 0
TDK 1.4.2.10 link
I have a link for the TDK 1.4.2.10 software.. TDK 1.4.2.10 I did manage to crack it using the instructions in this forum. There are two problems 1. If I patch the files myself, there is an error "License invalid. Shutting down Stack Server". and it refuses to start. 2. If i use the patched files. There is no error but only serial port is getting activated. No other profiles exist. I have one more doubt. Is it possible for me to update my anycom firmware to TDK. I have the DFU file but it always says failed. Please help.. Thanks |
Member: 41353 Status: Offline Thanks: 0
If you got this as an INTERWRITE update then this would probably be the way it should work (serial port only) as this is a special update intented for buyers of this hardware.
Well that is what I thought at first. But I had a look at the files. It had all the requisite inf files required for the rest of the stuff to work. I am not too sure whether it means that all the profiles will work. Anyway my two cents.
I am currently using a cracked 1.4.2.10 SP5 which I downloaded from a link in this forum. I used a TDK 1.3.2.19 before this. I have noticed that when I used TDK I did not get explorer.exe errors which i now get. that is why I am interested in these. Thanks for all the help. |
