Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900. |
12-27-2003, 11:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: India Age: 39
Member: 20691 Status: Offline Thanks Meter: 20 | V200 Camera Problem Solved :-) Friends... This proplem was discussed many times on the forum, but this time i am putting it in a proper way, with the link of flash file that is Used. Thanx to my friend Mr. Justin (SUN) Note :- Use WinXP only. How to BACKUP you phone First :- 1) Open OptiFlash program go to Options\Settings\COM Port, set First COM Port only, disabled Second COM Port (none) . 2) Click READ tab deleted all the existing read ranges and add the following up ranges: 0x00000000 - 0x00000617 0x00004000 - 0x00007a43 0x00010000 - 0x00576a53 0x00700000 - 0x00cbd713 Then click on ok. 3) Take out the sim card, connect cable to phone and then click on READ...software will then ask to power on mobile, Press the pwr button on phone for about 1-2 seconds ( You will NOT see the phone come on!! ). This will take about 10 or so mins to read the flash..file output is 34 mb. It will say "all is well" when its finished reading. remove battery and put it back on. 4) Now goto options settings FLASH & VERIFY tab then open the file that you just saved which is the flash of your own fone. Click ok and then click on VERIFY. If it verifies 100% it will say all is well. remove battery put it back on. IMPORTANT NOTE IF YOU GET ANY ERROR HERE DURING THE VERIFY PROCESS I HIGHLY RECOMMEND THAT YOU NOT CONTINUE. How to FLASH your phone to Remove Camera Error :- 1) Goto options\settings\flash and verify, open the new v205 flash file its called V25UVVL2.sre Flash file is Here : http://www.gsmvietnam.com/free/samsu...5/V25UVVL2.zip 2) Clear Reserved memory regions (blank, no need to type in any range) . 3) Click on Generic tab, select Customer T1, v200 in specify hardware platform. Then press ok. 4) Click on FLASH buttom start to flash. software will then ask to power on mobile, Press the pwr button on phone for about 1-2 seconds ( You will NOT see the phone come on!! ). This process took about 20mins then it said all is well. At this point it was done. 5) Remove cable and battery, then put the battery back on then turned on the phone (without sim card). 6) When phone ask you to insert sim do this resets (each one will reboots then insert next code) *2767*MEDIA# *2767*FULL# *2767*CUST# *2767*WAP# *2767*STACKRESET# (After the phone reboots "Personalization Cancelled" should be displayed.) If "Personalization Cancelled not displayed then don't worry, just power ON the phone and you will see "Wrong Card" on your phones disply... for removing that you can use any V20x unlocker for WinImei to get the safe unlock codes. 7) If after unlocking you din't see the network bars then go to Network Settings and change the band... That's all your phone is Done ... Regards, Tanvir !!! |
12-27-2003, 15:08 | #3 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | Sorry.... But is it not the procedure for FLASHING the phone with OPTIFLASHER only ?.... just explained....nothing about the camera ..really!! WBR Syed |
12-29-2003, 12:23 | #6 (permalink) |
Member: 20691 Status: Offline Thanks Meter: 20 | Friends... this solution given by me will only solve the problem in V200 if your phone's camera is not working and phone shows this Error while using camera "Remove Cable or Irda" If after Using this solution also your phone's camera is not working then it must be an Hardware Problem, Check out the hardware solution for it : http://www.vsh-gsm.com/forum/showthr...s=&threadid=99 Thanx to Vahid ;-) And yes V200 have these Following Features while V205 don't have it : - Added Features: 1. Hide Operation Logo, time and date. 2. Camera zoom. 3. Upload the cam pictures to PC. 4. Activate Folder Tone (same as S300). 5. More keypad tones (Cool & Piano). 6. New startup screen. (T-Mobile is gone) 7. More wallpapers. 8. Animation when searching service is different. 9. Restricted: Call Barring, Closed User Group. 10. MMS and WAP settings with out entering the code. And more......... Regards, Tanvir !!! |
01-08-2004, 21:58 | #8 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | If its hardware problem why with V200 fw camera error & with V205 camera work?I think its some calibration setings in flash (lyke emulated eeprom zone)U can try to flash only from 0x00004000 - 0x00ffffff or from 0x00000000 - 0x00001fff.Not all flash regions. Its ghast an ideea. |
01-11-2004, 07:23 | #11 (permalink) | |
No Life Poster Join Date: Jun 2003 Location: Twin Towers Age: 36
Member: 30582 Status: Offline Thanks Meter: 1 | Quote:
What is the language? wbr | |
02-03-2004, 16:15 | #13 (permalink) |
No Life Poster Join Date: Apr 2003 Location: pakistan Age: 44
Member: 27289 Status: Offline Thanks Meter: 24 | link down can any one send me the flash file since the link is down e-mail [email protected] |
V200 camera problem | Unlocker AL | Trident/AGERE Platform | 5 | 09-13-2004 12:23 |
E700 and V200 camera problem, need help!!!! | taihv | Trident/AGERE Platform | 26 | 06-16-2004 12:14 |
V200 camera problem | pstamov | Trident/AGERE Platform | 4 | 01-06-2004 18:28 |
Samsung V200 camera problem | Raklm | Samsung Hardware Repair | 5 | 09-20-2003 01:14 |
sasmung v200 camera problem | Moosani | Samsung Hardware Repair | 0 | 07-24-2003 21:35 |
