| E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
![]() ![]() Join Date: Dec 2003
Member: 47665 Status: Offline Thanks: 0
I have problem with using Freia. I don't get any errors or problem make firmware & eeprom with Freia software, but I cant unlock my phone model A56(A55 in Europe). Do you guys have any ideas what's going on? I get below messages in process information box and I don't think my phone is unlocked. I tried use my phone(A56) for A55 or C55 to unlock...but nothing works... Please help.............. FREIA - Engine build 8, Frontend build 3 Thanks goes out for the following: Maxim, Rolis, Sergey, PapaJoe, Lead, TheWizard, Jozso (for hardware and cable support and of course beta testing), Nico, Victor, Pinker, Tom, and all the others who supports ... COMM_LoadBoots : selected phone family is 8 TTY_OpenCOMPort : opening COM1 COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_LoadBoots : internal loader version is 01.00 COMM_LoadBoots : EEPROM IMEI is 01012751377489 COMM_LoadBoots : original IMEI is 01012751377489 (locked) COMM_LoadBoots : found SIEMENS A56 lg1 v19 (1) COMM_LoadBoots : flash ids are 00890017 [00000000] - 1789 COMM_LoadBoots : phone ids are BE55AD41 [BE55AD41] O.K. I guess I need either unlocked A56 or C56 firmware or eeprom. Just my guess....let me know if you guys know or have unlocked firmware. Last edited by senorulz; 12-31-2003 at 08:50. |
Member: 38947 Status: Offline Thanks: 0
I have used the Siemens Service Tool from
http://www.sst-gsm.nm.ru/ to unlock my A56. It worked! To find out the locks of a SIEMENS phone: Take out the SIM and switch on the phone. Press *#0606#, then "Info" (left Softkey) If you get 5 x "Unbarred" there are no locks! Last edited by Schlips; 12-31-2003 at 21:38. |
Member: 48016 Status: Offline Thanks: 0
Did you use the full or freeware version of the siemens software? I found that the unlock process stops in the middle.
you mean Freia? Freia is a free software....should be aiite...
but Siemens Servie Tool box,, I used it.. and result says unlocked.. but i dun think it's unlocked |
Where can I download Fiera?
I used the Siemens toolbox, what happened was that I plugged my a56 to the cable, pressed the "unlock" button, when it asks for power on, I pushed the power button, then it loads something from the phone and stops. it doesn't seem to be doing anything for around 2 mins so I just pulled the phone from the plug. Then I checked the phone and its still locked, so the program did nothing to it. Anyone has any idea how I can get this program to work for me? I am willing to try other programs too. |
Siemens Service ToolBox v4.00(latest version) - without a testpoint
http://www.sst-gsm.nm.ru/ToolboxFree.zip Freia Engine build 8, Frontend build 3 (latest version) - without a testpoint http://www.siemens-java.com/PROGRAMI/freia.rar Both are freeware... no registration or a dongle required. Best Unlocking Software for Siemens, but I don't think they are really working. Some says working, Some don't... Use bulk china cheap serial cable for Siemens, and com port or any settings with port... just stay default, you don't have to change anything with COM1 OR COM2 port. but the speed of connection... I recommend 5xxxxx somthing....slowest for stability. In case with unstable connections, use Clean Windows 98 Second Edition re-installed. both software still seems have minor bugs.... some errors...I found. Last edited by senorulz; 01-02-2004 at 08:52. |
Thanks for the links!
I'll post results of my findings. I am still scratching my head why the 'siemens toolbox' stops when it's unlocking my phone. Its obvious the program and the phone communicated.. and it's not like a fatal error occured during the process(i.e: program freeze).
There are a few things, you should check:
- NEVER use the original SIEMENS cable at a "real" COM port. It won't work (has been mentioned!). - AVOID the use of an USB cable. It might work - or not. - CHECK the port settings. The ones in the program and the one form your computer (Start / Settings / System I think). Is the FIFO on / off? |
Com Port settings just go DEFAULT
DEFAULT is FIFO on |
Member: 48388 Status: Offline Thanks: 0
Did you have any luck unlocking your A56 yet? I have the data cable and I'm wondering which software to use. Thanks in advance.
#11 | |
Member: 34188 Status: Offline Thanks: 0
Freia
I have a FREIA build 8. Just pretend it is an A55. *assumption*.
email me gaunt911@gmail.com I can email you the software.. Quote:
