| Universal Software Write here for questions about Universal GSM Software. Example: USPU, twinsim, sms-soft, drivers... |
![]() Join Date: Jan 2001
Member: 3000 Status: Offline Thanks: 0
Plz i need to download the new USPU software ?? any one konow where to get ?
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2000
Member: 2583 Status: Offline Sonork: 100.88702
i didn't get it from this site , but try and tell me ..
passwd available in post here if don't know , tell me to search for this post in my hd. http://afilip.50megs.com/software.html#s7 Regards |
![]() ![]() ![]() ![]() Join Date: Nov 1999
Member: 696 Status: Offline Thanks: 0
Yes, USPU from this site works, but link is not very good, so use GetRight when you download. Password is: Technologies18 (Case Sensitive)
Regards, MASHCO |
Member: 2466 Status: Offline Thanks: 2
Can I 100% unlock Alcatel 170 with USPU 4.38 and can I do it with misiek universal cable wich I use for older Alcatels?
Thanx all..
i'll try to download it now . Best regards GSM_Hacker |
i got the software and setup it on my system .
Thanx Meshoz and mashco but when i used to unlock my db View ver 16B BE3V-1DFLJO1 .... Phone dead ![]() any one used this unlocker before with db view ???? any help plzzzz !!!! Thanx alll |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2000
Member: 2822 Status: Offline Thanks: 12
hi,
is your set up of uspu 4.38 working????? i also downloaded ths same soft for more than 10 times with out any erreors, but when i run set up and installed crypto.cox in c:\windows\system dir; my comp says REINSTALL USPU SOME FILES ARE MISSING. i am unable to remove this problem may be you can help me. regards ashwani gaur e-mail ashwanigaur@ashwinsmail.com |
Member: 2724 Status: Offline Thanks: 0
To GSM_Hacker:
USPU 4.38 unlock Alcatel View DB up to v170 - (........,167,169,170 !!! It don't support v 16B ! |
To Ashwani Gaur :
the downloaded file is 100% working ... but you have to setup USPU 4.38 into USPU 4.35 directory so .. u have first to get USPU ver 4.35 .. if u read setup instructions carefully u will verify this . i setup my software into this directory and no error message with it. To scum : so is there any way to unlock such db (16B). ????? and thanx to u Best regards GSM_Hacker |
#10 | |
sir, thanks for your replay in gsm forum.
i tried each and every thing known to my knowldgeto make it working but failed. i eariler downloaded uspu 4.3 from same site last year in dec. it was as in zip format (full)+ crack zip(crypto.ocx). i installed it and it worked fine. but when i down loaded uspu4.38 as RARzip.IT FAILED TO WORK FOR ME . may be i am doing some mistake. can u please help me to how to install it correctly. with regards ashwani gaur Quote:
![]() ![]() ![]() ![]() Join Date: Jul 1999
Member: 318 Status: Offline Thanks: 0
I've got my update copy from www.gsmfactory.com , software section .
After unzipping the two files , update & crack , I run the update file , confirmed the 4.35 dir as c:\program files\uspu4.35 then i run the crack.It found 3 "signature" , then all is ok. I unlocked a db 163 successfully , with vpp linked directly to the 1n4148 diode. |
TO : Ashwani Gaur
Man i downloaded the file from http://afilip.50megs.com/software.html#s7 and i setup it into my past directory of USPU ver 4.35 and it worked for first time !!!! i dunno what's happen to u best regards |
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2000
Member: 2188 Status: Offline Thanks: 0
Hi, I posted in my web site USPU4.38r upgrade program + crack. You must have USPU4.35 installed and then run this program. I tested it and it works 100%
Best Regards, Westerna http://westerna.hit.bg |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2001
Member: 5926 Status: Offline Thanks: 34
http://www.zshare.net/download/625682731b0b069e/ or http://www.megaupload.com/?d=SLG5LUBX
here also alternative download link all others not working anymore and perhaps someone need it. BR |
