| Samsung Wallpapers,Ringtones Only Ringtones, Wallpaper and other media Files. |
Member: 50106 Status: Offline Sonork: 100.109487
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003
Member: 20069 Status: Offline Thanks: 0
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002
Member: 8353 Status: Offline Sonork: 113276
call me at 0300-9200098 (karachi)
Super Moderator
![]() Join Date: Nov 2002
Member: 17651 Status: Offline Sonork: 81230
Use Private Messages for contact eachothers.
otherwis " send me to " contast will start here agian .. ![]() WBR Mobile Lab |
Member: 8304 Status: Offline Thanks: 3
Why dont you create your own mmf's from your own songs,very easy.Post here if you need instructions.
#6 | |
y don't u post the instructions here ...so we can get some useful info from u ...wbr the_frightener |
#7 | |
![]() ![]() Join Date: Dec 2003
Member: 46862 Status: Offline Thanks: 0
yes all want this solution please post here instructions for all |
This is how you create mmf voice tones
Here we go: 1 - you must use*.wav file to create *.mmf 2 - u can use Windows Sound recorder or Audacity or Goldwave to cut the selection you want,normally the chorus of the song. 3 - Open Sound recorder and open your wav file 4 - Play the song until you see the part where you want the tone to start,now click stop. 5 - Click edit and then go down to "delete before current position",this will delete all audio before that position. 6 - Click play again until you see the part where you want the tone to stop and click stop. 7 - Go to edit again and Click "delete after current position",this will delete all audio after that position. 8 - Now you should have a small audio file which you want to use as a tone. 9 - Click effects and click "increase volume by 25%",do this 3 to 4 times to make your tone louder.Now click save. 10 - Now you have to convert sample rate with "cool edit pro or other audio edit software. 11 - Open wav in cool edit pro.(select your wav and doublleclick to open). go to edit then select "convert sample type". Sample rate is 8000. just below make sure pre post filter is checked off and raise the bar to high quality - 999. Channels are set to mono and resolution is 16 bit.Click save. 12 - still in cooledit click on effects, then the noise reduction tab then click on noise reduction. Click on get profile from selection. Then slide the noise reduction level tab so that it is halfway out of the green section.I set the value to 6, click ok. save file. 13 - Now you can convert this file to *.mmf with Yamaha wsc-ma2-smaf converter.Just drag the *.wav file onto the converter and dont click 8mhz-4mhz,Just click ok. 14 - Now your mmf voice tone is created. HINTS: - For s300/v200/c100,etc the max file size is 40kb ~ 12sec For s500/e700/x600/x100,etc max file size is 32kb ~ 8 sec Songs with alot of bass need bass reduction or this sound will distort if you make it too loud. |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2002
Member: 14578 Status: Offline Thanks: 117
thans mr. mujie,
w.b.r. |
it is good information for all
thanks you very vry vy much |
Make your *.mmf voice tones vibrate with flashing l.e.d
You cant add vib and led to an mmf tone but you can add it to a 8000 8bit wav file. after you have the wav file ready here is the tutorial: -Use ats-ma3-smaf -use empty midi file -Open the yamaha program -Click on the green open folder -find the empty midi file that u downloaded in step 2 and open it, a window will pop up and click ok -Click on Window > Stream PCM Assign Map -Right click (in the Stream PCM window) on the first row and Click New -find the wav that you want to be your ringtone. -in the Score Window click on Piano Roll in the upper left hand corner of the window -Drag and drop your wav file (from the Stream PCM window) into the gray area (in the Piano Roll window) -go back to the Score Window, scroll to the bottom -click on the one of the two empty boxes next to the STM -a window will pop up and where the two white boxes are click on VS to add vib and LED to add led -File > Save and youre done. Downloads follow!! ALL CREDITS GO TO "RAAB HIMSELF" |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004
Member: 56561 Status: Offline Sonork: 100.114006
Thanks but ?
Thanks a lot to give us a informative thing, i have 1 question when i reduce the noice the volume is toooo slow, please tell me how can i increase volume of songs with no noise ?
#15 | |
