Old 02-18-2004, 16:23   #1
iPAQ_h4ck
Member: 54550
Unhappy HID profile not loading before logon screen
I have recently got my MS BT dongle working on WIndows XP Home by using the using the HEX edited IBM widcomm drivers described by Phantasm in other threads, and all seems to be fine . MS keyboard and mouse work fine once logged on, but HID profile does not seem to load before logon screen when PC is rebooted, ie can't use bluetooth keyboard or mouse to logon.
I have read on the net that HID profiles are supposed to be loaded automatically by Windows before the logon occurs.
Just wanted to know if I had missed a configuration, or if there is a setting I need to change?
Thanks!
Old 02-18-2004, 17:20   #2
w-k-pieters
Member: 44064
Originally Posted by iPAQ_h4ck
Thanks!
You have probably installed the software while logged on on a limited user account. So you should try to install the software either in the safe mode or when in an account with administrator rights.
Old 02-18-2004, 17:32   #3
iPAQ_h4ck
Member: 54550
All software and drivers installed with administrator account on the PC.
What difference would installing it in safe mode make?
Old 02-18-2004, 19:59   #4
w-k-pieters
Member: 44064
If you installed it while being the administor; none.
Old 02-20-2004, 12:57   #5
leemperor
Member: 44457
Windows does load HID profiles before logon, but i don't know when it runs the widcomm drivers. Maybe the problem is related to that, but it works for other people so there must be a way that it can communicate before logon. Do you have the "intelli" software installed for your mouse and keyboard?
Old 02-20-2004, 13:10   #6
leemperor
Member: 44457
Do you have the bluetooth service set correctly?
Mine is set to "System"
[IMG] code is Off
Page generated in 0.07485 seconds with 6 queries
