Member: 57135 Status: Offline Thanks: 0
How to get completely rid of MS Intellipoint SW??
Hi there!
I switched from Widcomm 1.4210 to 1.4.3.4 due to problems of loading the BT-Stack driver at startup of Win XP. Now even with Jonīs excellent instructions my MS Bluetooth Intellimouse and the MS BT-Stick arenīt recognized whatsoever. Iīm always being prompted for those §$$&% bth_oobc.dll and Q323183, how do I completely get rid of this MS nonsense? Thanks. |
![]() ![]() ![]() Join Date: Nov 2003
Member: 44457 Status: Offline Thanks: 0
I think it is possible to get the Widcomm software to co-operate with the microsoft drivers so you don't have to nuke them. This is actually probably a better solution than nuking the MS drivers. Have a look at the advanced section of the guide (I only added this info about 2 days ago)
http://www.jonscaife.com/bt/details.html#microsoft I must stress that I haven't tested this yet myself as I don't have the MS drivers or any MS hardware. I have based this on some very detailed correspondence. If you have any problems with it or anything is inaccurate please let me know Cheers Jon |
#3 | |
Member: 57207 Status: Offline Thanks: 0
Hi, I too have tried it. Doesn't appear to work. Widcomm doesn't recognize the MS bluetooth adapter for some reason... It does work with Blue Soleil though.
#4 | |
OK, it works now. After installing the Widcomm drivers as instructed by Jon on his website, I manually updated the the transceiver driver to the one by Widcomm (tell Windows to look for the drivers in the C:\Drivers\WIN\BDCACT\ directory for the btwusb file. After, the driver is loaded into C:\windows\system32. After that, update again, but this time, pick from a list. Now you will have two options.... the driver by MS or by Widcomm. pick the Widcomm one.. I think that's it).
OK, itīs working now but I had to uninstall the MS BT-Service Pack, then use bth_oobc.dll and "manually" install the btwusb.inf. With the BT-SP installed it was a no-go because the stick was already recognized by the system but not by the Widcomm-SW.
Thanks for your advice. Markus Last edited by intorange; 03-09-2004 at 14:12. |
