04-17-2004, 15:44 | #1 (permalink) |
Junior Member Join Date: Apr 2004 Age: 46
Member: 62729 Status: Offline Thanks Meter: 0 | Help with Sim Emu6.01 and SilverCard ! I have problem with Sim Emu 6.01 and SilverCard ! 1. I have created 6.01s hex file ! 2. I have put in my KI + IMSI + PIN1+PUK1+PIN2+PUK2 3. I have programed SilverCard with my Mastera prog. and CardWriter 1.87 4. Here is the problem begins When I start Sim-Emu 6.01 Configurator v2.1 it ask me to enter pin1 ! I use the pin1 which i have defined BUT I get error (Wrong pin1) ! I have tryed it for a couple of ours but it isnt work ! My card is blocked down ! PUK1 is wrong too ! I have changed pin1 en puk1 more then 20 times but result is the same ! The same is then i put silvercard in my mobilephone ! PLEASE HELP ME ! Regards ! Viacard42 P.S. When I tryed to program my SilverCard with ICprog or PoniProg ! Sim-Emu 6.01 Configurator v2.1 says what it cant reset this card ! and mobilephone cant recognize this card too ! |
04-18-2004, 18:37 | #2 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Spain Age: 62
Member: 10582 Status: Offline Thanks Meter: 99 | With the Configurator, check the files you have configured, (Flash and EEPROM). TO do this: 1) Open the configurator without any card 2) In the Configure tabsheet, check Card Config Mode. 3) Press Read from Disk and open the files you have configured (flash and EEPROM) 4) See which data you have configured. (PIN's and another) If all is as you expect, you must to write the files again with verification too. I recommend to write external EEPROM with Configurator too. Regards |
04-19-2004, 09:45 | #3 (permalink) |
Member: 62729 Status: Offline Thanks Meter: 0 | Hello SimEmu ! I have found error ! It was problem with CardWriter 1.87 : on address 00A0 must be 1111 (pin1) :FFFF:2222 (ect) BUT CardWriter had write this address like this: FFFF (pin1) FFFF:FFFF So I have maual changed 00A0:FFFF to 1111 and it works fine ! Thank you in advance ! Regards ! Viacard42 |
Please help with info (SE debug), and I will try to help with repair | Alkapone | Sony Ericsson Hardware Repair | 0 | 01-17-2006 20:34 |
Problem with SimEmu 6.01 and Nokia 3650 | Maxim Gavrilov | Sim Cloning and Scaning | 4 | 05-31-2004 18:50 |
Find a bug about sms service center in Sim-emu6.01 | Luluk | Sim Cloning and Scaning | 1 | 01-20-2004 01:44 |
problem with simemu 6.01 and nokia 3650 | diapolon | Sim Cloning and Scaning | 0 | 10-24-2003 09:52 |
