| Nokia Old Generations DCT-1 & 2 1st & 2nd Generation of Cellular Technologies, Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx ...etc. |
![]() ![]() ![]() ![]() Join Date: Mar 2001
Member: 3815 Status: Offline Thanks: 0
i am not very familiar with the 3110 but whenever i press the call button (with or without entering number), it says "call not allowed". why?
only emergency calls were allowed. pls help!!! <FONT COLOR="#ffff00" SIZE="1">[ 10 April 2001 08:59: Message edited by: pks ]</font> |
![]() ![]() ![]() Join Date: Apr 2001
Member: 3968 Status: Offline Thanks: 0
Hi, I used to own a 3810. Not exectly the same but quite similar. I'm not 100% sure but its probably due to any of the following:
a> Call cost limit setting b> fixed dialling on (should be off) c> any of the call barring features You could also try to use another SIM card. If it works, Its in the phone settings. Best regards, MUSCLEMAN |
a> none
b> off c> outgoing calls: service not active i used both my simcard and both doesnt work (but they worked in my other fones) |
I guess the last resort would be to reset to factory settings
BR MUSCLEMAN |
i dont have the cable for it
can logomanager retrieve it if i do have the cable? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
Member: 3617 Status: Offline Thanks: 233
You dont need the cable, just go to the settings menu and find restore factory option, phone will ask for phone code, put 12345 the default, and its all.
regards |
the problem is, the security code isnt 12345.
Than use Nokia_Tool_by_pro_035 to read the security code with Mbus cable, than use it.
regards, |
dun worry. i calculated imei from sid.exe. thx anyway
![]() ![]() ![]() ![]() Join Date: Nov 2000
Member: 2628 Status: Offline Thanks: 0
Look after if the operator send on GSM-1800 or GSM-900 in your region !!
Plase sent me a sw to unlock Simlock of an 3110 old phone,
regards, |
sid.exe only calculates security code and not simlock codes
#13 | |
Member: 7168 Status: Offline Thanks: 1
what the problea it it my card damage but i can receve the call |
