| Nokia Old Generations DCT-1 & 2 1st & 2nd Generation of Cellular Technologies, Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx ...etc. |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2001
Member: 5006 Status: Offline Thanks: 0
Please can you help me. I have a 6210 v. 4.27. However i forgot the security code. I got a datacable and run Logomanager. It said the sercurity code was 22298. However when i enter this into the phone it replies with "Code error". Can you please give me a solution for the problem. Is there anyway i can enable it through net monitor in logomanger, or by unlocking it with the dejan flasher. Thanks in advance.
Super Moderator
![]() Join Date: Mar 2001
Member: 3756 Status: Offline Thanks: 0
Hi!
You will have to reset the phone to the factory defaults... i had the same problem in 3310 but i used nokia tool to reset it... Use nokia tool and Apply SFS....but you will loose everything...logos, ringtones, etc... I guess you can give it a try no? Cheers... <FONT COLOR="#ffff00" SIZE="1">[ 01 July 2001 20:25: Message edited 1 time, lastly by [MoOkIe] ]</font> |
![]() ![]() ![]() Join Date: Sep 2000
Member: 2006 Status: Offline Thanks: 0
I could never get this to fix the problem, Also if you read the code it is always wrong.
The only 100% succesfull way I found was to use Wintesla for a full factoy reset. |
![]() ![]() ![]() ![]() Join Date: Apr 2000
Member: 1266 Status: Offline Thanks: 0
Using Nokia profile 1.10 to set default!
everything reset! Cool! easy! ![]() <FONT COLOR="#ffff00" SIZE="1">[ 06 July 2001 05:53: Message edited 1 time, lastly by Supergsm ]</font> |
![]() ![]() ![]() Join Date: Apr 2001
Member: 3968 Status: Offline Thanks: 0
Hello JJ08,
If all else fails, use your Dejan Flasher and backup address 00500000 to 00600000 and keep that file. then read address 005a0000 to 00600000 and e-mail it to me then I'll e-mail you the unlocked flash file. Regards, Muscleman |
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2000
Member: 871 Status: Offline Thanks: 0
Hello Guys,
To fix security code problems with 7110 and 6210 read the 6210 forum. Posted by Brobble: "Lord means the right solution, but his way is wrong, because the counter is not ever on same adress! The phone uses "Searchindexes", so we tell them, to read or save datas into PMM! For example you are looking for Snake-Highscore on 6210, the phone search in PMM for F4770000 and will find it! After that come 55FF (always the same), than comes checksum, lenght, adress and then the snake-highscore! It´s cool for editing this highscor! That is the solution for the whole PPM. If you start the phone, then it check: May I accept the right Security-Code or not? For that, it looks for the counter (It isnt a counter, but we told it so, because first we believed, it´s a counter!) It´s a status byte! "Searchindex" is F4480000!!! After that 55FF, Checksum, length, adress, and the byte self! If this byte is 06(hex), than the phone wont accept any Security Code! So change it to 00, dont forget the checksum of this byte, of course 00, too! An example: F4 480000 55FF 0006 0001 7C05 06 So it looks, when it wont accept! Change it to: F4 480000 55FF 0000 0001 7C05 00 Now the counter is Zero! So it will accept 12345 or the saved Code under Serchindex F44A0000! You must read out phone from 005A-0060 for 6210 and from 0059-0060 for 7110! Than just search or "F4480000" and you will find the counter. Here are listed our found PMM-Indexes: 770000 Snake2-Highscore 770001 Pairs2-Highscore (Time) 770003 Pairs2-Highscore (Tries) 4A0000 Security Code 480000 Security Code counter BTW: The highscores are not saved decimal, they are saved hexadecimal! Here the windows calculator is very helpfull! :-) Have fun! Greetings MR... [ 03 July 2001 19:13: Message edited 1 time, lastly by Brobble ] -------------------------------------------------------------------------------- Posts: 67 | From: | Registered: Oct 2000 | IP: Brobble Insane Poster Member # 2276 Member Rated: posted 03 July 2001 18:55 -------------------------------------------------------------------------------- I forgot: My solution (the first one :-)) was deleting all of PMM with FFFFFF, only not the block headers! You should not do that! Viper and I found this better (best) solution! Greetings to him and all other, who are finding secrets and release them for free! :-) MR..." This is not applicable for 3310! only for 6210 and 7110... Use HEX Editor (of course). Nokia Tool cannot reset blocked security code counters! Only Wintesla with original dlls for 6210 and 7110 can. Best Regards, X-Shadow |
