06-15-2004, 19:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: in the net Age: 46
Member: 37111 Status: Offline Thanks Meter: 96 | error 3.32 bad environment problem i get this error message with sam ufs 14 h i installeled the new usb drivers after uninstall the old ones but still cant flash them and i have parallel other error message like this MCU File: E70AEWI2.bin CheckSum: 58CA1B62 TFS File: E70AEWI2.tfs CheckSum: 24051D6B CFG File: E70AEWI2.cfg 10602 bytes Flash Device: Samsung KBB05A300_T 2nd Boot Failed: Baud Rate Setup Fail i need help |
06-16-2004, 12:38 | #2 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Worldwide Age: 43
Member: 23312 Status: Offline Thanks Meter: 1 | Ask your resseller, he will help you Try to click trought the function ( flash, unlock) without battery and then put it on. Regard Jose Ramon www.unlock-shop.com |
06-16-2004, 15:56 | #3 (permalink) |
Member: 37111 Status: Offline Thanks Meter: 96 | still the pb the problem is now the same i tried the same method you told but the pb is always ther even with dect P authorisation eror 32 even after update key box |
N-box Error Bad environment 31 bad library | GSM PAVIA | n-Box | 2 | 11-05-2008 13:21 |
help mt twister : bad environment | stranger55 | Twisterflasher | 2 | 07-06-2006 07:06 |
I can not repair S700i - Script error: Flash error [3.32.60]. What is it? | GsmService.Ru | Cruiser Suite | 15 | 03-27-2005 05:50 |
3.32 Cruiser not support LG new 8130 same problem | simlockman1 | Cruiser Suite | 1 | 03-24-2005 19:56 |
