![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003
Member: 21508 Status: Offline Thanks: 26
BenQ S660C unlocking problem
I have made the cable as shown on photos, when i click on UNLOCK and power ON just after it shows "Operation Failed" ?? i tried with with two connectors and N22i cable powered by 9V battery...
![]() ![]() ![]() ![]() ![]() Join Date: May 2001
Member: 4584 Status: Offline Thanks: 3
look the schematics here.
The best is too use a Nokia 8310 headset connector with nec 22i cable or lg510. |
i forget ;-)
9 Volt is too high. 4.5 volt is enough. BR. Steve. |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2001
Member: 3267 Status: Offline Thanks: 2
is this the same lead for 02x2 ?
yes exactly the same
cheers , just made the lead and unlocked my first o2 x2 , I did use a 9v battery tho what battery is used on the video on your webpage ?
New Update !! Sharp GX30 & ALL VERSIONS X60 !
i used 4.5 volt in the video ;-)
ok thanks , the update is not downloading for the gx30 , btw great updates again !
wait 1 hour for gx30. making protection now ;-)
ok , sorry , I am too eager for update
here is better diagram i used
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002
Member: 13737 Status: Offline Sonork: 100.100725
yes if u use 8310 handsfree connector and lg510 with power supply (9v)
done 1 o2x2 |
thanx for your help guys.. i changed the N22i cable and used the LG510.. the BenQ S660C is unlocked
![]() ![]() ![]() ![]() Join Date: Apr 2004
Member: 63553 Status: Offline Thanks: 1
Had another one of these to unlock, as UHK said first one we did was fine. This second one the battery connector came off as the progress got to 52%. Managed to get the phone to reconnect and progress then to 82% but got an error saying interger value overflow? (i think that is what it said) definately interger overflow and software crashed. Tried with the phone again and just got the interger error, no progress at all.. any ideas?
#15 | |
Hello. You got success before with other phone , or this is his first phone ? What happened exaclty if you try to make unlock more than once ? , is progress always stopped on the same place ? ... is the battery charged ? which other sw is running on your PC when you try unlock benq ? also cable can be problem too , or some pbs with protection ... also , which win system you use ? This second one the battery connector came off as the progress got to 52%. - why battery connector ????????????? if you have remove the batery during the unlock , so let's you try to do the same with panasonic 67 /87 =)) after this any pb can be appear .... if so , you need tool for repair or clone , but not for unlock. anyway is necessary to know all details ... step by step , what you did. actually benq is not so easy to kill as pana , but ... sometimes the same story happened with any other model ... nokia too =) i hope all this can help you. BR. Steve. |
