Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > LG
Old 09-08-2004, 22:12   #1
dark
Member: 6250
LG 510W no network after flash
hi
after flash 510w orange phone is unlocked but no network .How solved this problem? U tray two flash but no result.did anyone traying clone these phones and software for that?
br
dark
Old 09-08-2004, 22:49   #2
moldovan
moldovan's Avatar
Member: 23684
Sonork: 1582723
What Flasher You used?
WBR.
Old 09-08-2004, 22:56   #3
moldovan
moldovan's Avatar
Member: 23684
Sonork: 1582723
Go to Network menu , select MANUAL SEARCH and phone found Network , after set AUTOMATIC.
Post result here.
WBR
Old 09-08-2004, 23:10   #4
dark
Member: 6250
hi
hi moldovan
u used FLOADER V2.1
yes sometime in manual search phone find network with all bars on signal strenght but disapear in second.phone before flashing work ok..I think some
parameter in eeprom is destroyed.
Old 09-08-2004, 23:14   #5
moldovan
moldovan's Avatar
Member: 23684
Sonork: 1582723
Check IMEI. Is same with cover?
WBR
Old 09-08-2004, 23:19   #6
moldovan
moldovan's Avatar
Member: 23684
Sonork: 1582723
With Floader v2.1 You can,t owerwrite EEPROM and CalData , only if was computer error when You flashed phone.
WBR
Old 09-08-2004, 23:22   #7
dark
Member: 6250
hi
yes imei is same .
i need calibration data (i think) or full flash.
i am new in lg so dont blame me if i say somethink stupid.
dark
Old 09-08-2004, 23:32   #8
moldovan
moldovan's Avatar
Member: 23684
Sonork: 1582723
Before flashing You must read CalData with Floader v2.1 and store on You computer for easy work {sorry for my English}. Read CalData now , here contains You ORIGINAL IMEI , and MAY BE destroyed RX and TX and Battery calibrations parameters.
But I think problem in other place , becauce I repeat: With Floader v2.1 You can,t owerwrite EEPROM and CalData during write standart firmware.
WBR
Old 09-08-2004, 23:41   #9
dark
Member: 6250
hi
u tray tomorrow read one good 510w and write cal.data to my lg.
before flashing u not check sw version so it is possible to incompatibile sw version.if floader dont overwrit cal.data why is phone unlocked after flashing?
hovewer thx for help ill traying and post results here
br dark
Old 09-08-2004, 23:48   #10
moldovan
moldovan's Avatar
Member: 23684
Sonork: 1582723
CalData contain You ORIGINAL IMEI , and RX and TX and Battery calibrations parameters. Loks located in other place. In Floader box You have button OWCD--owerwrite CalData , but her is inactive.Read and save CalData with orig.IMEI , befere next experiment.
WBR Good night.
Old 09-09-2004, 04:03   #11
Drug_Store
Super Moderator
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
WBR
I´m a bit confused...
Humm... you say flashing doesn´t overwrite eeprom or caldata, but we all know that sometimes after flash some problems appear. For example, no network, battery callibration, sim-locks screwed up and etc... and sometimes this can be fixed by writting original caldata.
So if flashing doesn´t damage caldata settings, who or what does?
Thanks
Old 09-09-2004, 22:55   #12
moldovan
moldovan's Avatar
Member: 23684
Sonork: 1582723
Originally Posted by Drug_Store
Thanks
Hi Drug_Store! Read my posts with atention.
I writed about concretic Floader v2.1. This program have INACTIVE button OWCD----OwerwriteCalData in normal flashing process. And if IMEI after flashing is same with before flashing---CalData still original. You can damaged CalData with other Floaders for example v28 , where button OWCD is active or specialy used button Write cal. data near button Read cal. data
WBR Paul.
Old 09-09-2004, 23:26   #13
Leo140
Leo140's Avatar
Member: 43076
I have read all your post about that f ucked phone. I have same problem with you last few days
this what I have done :
get your NCK code
when use you manual mode to search the nerwork, wait until your phone find one, press 2945*#5101#
then menu 555
got to network
select Active then enter the NCK code
try and post result here
Old 09-10-2004, 00:16   #14
moldovan
moldovan's Avatar
Member: 23684
Sonork: 1582723
get your NCK code
then menu 555
got to network
Very interesting method . Will wait result from DARK.
WBR Paul.
Old 09-10-2004, 01:03   #15
Drug_Store
Super Moderator
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
WBR Paul.
You missed my point...
My doubt was when you say that flashing doesn´t damage caldata. But we seen some cases here on forum that even just flashing damaged the caldata. And some fixed the problems by writting the caldata backup. So I think this clearly means that caldata were damaged or written during flashing process.
And yes, flashing with 2.1.
PS: No need to tell me to read your posts or from anyone else with attention. Because, usually I don´t come here to play or distract myself
Page generated in 0.10894 seconds with 6 queries
