Old 09-12-2004, 06:24   #1
toukour
Member: 65975
Question Cables Problem with the new update 5.0
Blazer Update 5.0 released
This is what I got with the new version
Cable B is detected by software as B. ?
Cable E is detected by software as B. ?
Cable C is detected by software as B. ?
Cable A detected ok!
Cable D detected ok!
Please help Us .
Best regards.
Old 09-12-2004, 08:55   #2
EndlessConnections
EndlessConnections's Avatar
Member: 21371
Since ,youre in USA you shouldnt be worried about other cables and as for the Update, Blazer Team works on updates 24/7 and will resolve this issue soon.
Please help Us .
Best regards.
Old 09-14-2004, 19:59   #3
dannyogolo
dannyogolo's Avatar
Member: 18200
I think I have same problem
I tried to use cable C for 7100, but It detected it as Alcatel 320 Cable B
I tried E to, same thing.
Now I cant do anything with that phone.
Is this software or cable problem ???
I also tried with 4.9c and 4.9e, both give same error (though this was after first using 5.0)
Old 09-14-2004, 21:28   #4
Raskal
Raskal's Avatar
Member: 563
Sonork: 100.11111
We will double check it tomorow, and let post here results.
Old 09-16-2004, 13:29   #5
Phil
Phil's Avatar
Member: 2735
I had this problem too, eeprom content inside cables was wrong.
After reprogram them all is OK and works fine
Regards
Phil
Old 09-16-2004, 16:55   #6
toukour
Member: 65975
WE STILL WAITING FOR THE RESULTS .PLEASE
BEST REGARDS.
Old 09-16-2004, 20:27   #7
hoangminhtam
Member: 32182
i have problm. with the cable C1200 that i made after Blazer's hex n schema c1200.
the box can not detect the cable
inside, i use eep. 24c256 instead of 24LC256 as guided in schema .
m' I wrong ??
Old 09-17-2004, 10:53   #8
dannyogolo
dannyogolo's Avatar
Member: 18200
Yes, we are waiting for solution for bad cables
Old 09-17-2004, 13:37   #9
hakima
hakima's Avatar
Member: 33804
I have problem with cables "C" when working with G5300i!!!
Always must to press and hold power button untill all done!!!
WBR
Old 09-18-2004, 00:53   #10
doctormike
Member: 22586
Dear Blazer Team,
I also have cable problems:
Cable A is not recognized at all and get message : Insert cable
Cable B is recognized as E.
I tried versions 49 & 50 of your software.
PS. I am new user and have no older versions to check.
Running WinXP - SP1 and have tried on another pc under WinMe; results are the same.
Regards
Mike
Old 09-18-2004, 01:30   #11
Raskal
Raskal's Avatar
Member: 563
Sonork: 100.11111
Regards
Phil
I see teleway start copy cables to make it cheap.
Let see how cheap can make the uni box...
Old 09-18-2004, 14:15   #12
toukour
Member: 65975
We are all waiting for that.But what we should do with our bad cables ?
Old 09-18-2004, 15:09   #13
Raskal
Raskal's Avatar
Member: 563
Sonork: 100.11111
Ask your reseller for replacement and they will do that, is the fastest way.
Old 09-18-2004, 15:20   #14
toukour
Member: 65975
Thank you a lot .
Old 09-18-2004, 19:46   #15
hoang
Member: 10485
Sonork: 100.66876
WBR
Connect pn 15 to 18, that's all!
Page generated in 0.09730 seconds with 6 queries
