Old 09-19-2004, 13:27   #1
taopheek
taopheek's Avatar
Member: 44566
Blazer, Im Not Impressed
I just picked up a blazer, i tried unlocking cheap b1200 it says new version detected update sw, so i updated to 5.0. tried again i got d same messaege. fine i tried unlocking c1300 it said unlocked but the handset was still locked
i hope this not another lousy box, i need an explanation cos im losing money.
naija4real
Old 09-19-2004, 13:35   #2
Irinel
Irinel's Avatar
Member: 4201
naija4real
Hello,
about B1200, read full flash files from the phone and send me, i can help you very fast with update.
About C1300, after unlock press: 2945#*# go to menu and make Factory reset, and phone will be unlocked. All this is because you try to put for many times code in to phone. Make what i say and phone will be unlocked.
best regards,
Irinel
Old 09-19-2004, 13:55   #3
taopheek
taopheek's Avatar
Member: 44566
Thanx man i will try that and get back 2 u tomoro
Old 09-21-2004, 13:11   #4
taopheek
taopheek's Avatar
Member: 44566
Hey tried it and worked, u r d man................................
Old 09-27-2004, 12:23   #5
taopheek
taopheek's Avatar
Member: 44566
@Irinel i think i dont need to request an update cos i read the flash of a b1300 that i unlock and dumped on the on requesting an update and it worked so my advice is that users should just back up any phone they unlock.
Old 09-27-2004, 16:14   #6
abdoulaye
abdoulaye's Avatar
Location: senegal (dakar)mali/guinee/mauritanie[KANDJI ET FRERES]
Member: 41375
:::::hi:::::
and for probleme cable (C ,E ) î pây my box cable C, E not work
Old 09-28-2004, 11:40   #7
Irinel
Irinel's Avatar
Member: 4201
Originally Posted by abdoulaye
:::::hi:::::
If you have some problem with cables contact your reseller friend.
best regards,
Irinel
Old 09-29-2004, 20:38   #8
Flash-GSM
Member: 75138
C1300 not unlocked
Instead of creating another thread i'll just continue here as it has similar issues. I recently unlocked a US C1300 for a customer and tested it with a Cellular One (Dobson) SIM. the phone worked ok, it boots up just doesn't find network (I suspect 900 MHz band as we have only 850 MHz up here). I send phone to customer and emails me that the phone boots up but gives him the 'Phone Restricted' deal. I told him to do the 2945#*# and factory reset and all should be fine. this is his reply:
"Thank you very much for your restriction code but unfortunately it didn't unlock the phone. As soon as the phone boots up it reads "phone restricted" and then it asks you for a restricition code which is where we entered the "2945#*#" and the factory default. There is a little bit of differences in the phone when we entered the code for example after we enter the restriction code you indicated to go "to menu" and there was no menu option it was already there and then you said to go "to factory reset" and it was factory default."
Any suggestions?
thx
Old 09-30-2004, 22:33   #9
agent003
agent003's Avatar
Member: 19094
Any suggestions?
thx
Yea.... your customer wants a refund
Page generated in 0.08610 seconds with 6 queries
