![]() ![]() ![]() ![]() ![]() Join Date: Oct 1999
Member: 563 Status: Offline Sonork: 100.11111
For the ones with cable problems, please read !!
For the one have problems with cables, please contact the resellers for replacement. It can happens that cables does not work, it could be some mistake.
You can repair the cable very easy, you need open the cable wich is not detected by software and desolder the eeprom. Than you have to program the BIN file into the eeprom using an simple eeprom programmer. Please reprogram ONLY the cables wich has not been detected by software !!! You can download the eeprom content from: www.blazer-team.com/cables If you still have questions, please contact your reseller or support@blazer-team.com B.R., Raskal |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2003
Member: 33804 Status: Offline Thanks: 0
Thanks for ur good work!!!
![]() WBR |
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2001
Member: 6738 Status: Offline Thanks: 3
theree is another problem with blazer new cables, not this one
i have for example one lg 7100 with old blazer box and cable connects and works... with the new cable and box doesnt connect , we have tried different software from 5.0 and below. and the software says cable type C detected |
Member: 7368 Status: Offline Thanks: 0
same problem, cables detects well, but cable 'C' have communication problems with G3100, G5220 and working with G7100
Member: 10485 Status: Offline Sonork: 100.66876
Cable C for 7100 is pin out problem, read here to solve http://forum.gsmhosting.com/vbb/show...703#post856703
Member: 21978 Status: Offline Thanks: 0
Cable "D" missing ?
Regards |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2003
Member: 23684 Status: Offline Sonork: 1582723
Yes cable [D] missing , and write again what type of cable for what model of phone? Please.
And what must I do , when software detected cable write "LG cable detected", but not detected phone? Sad "Communication ERROR". WBR Paul. |
![]() ![]() ![]() ![]() Join Date: Dec 2001
Member: 7810 Status: Offline Thanks: 18
Cable model A work on: LG G650,C1100,C1200,C1400,G1600,C3100
Cable model B work on: LG B1200 Alcatel 320 Cable model C work on: LG G510,H510,G5200,G5220,G5220C,G5400,G5410,H3000,G70 70,G7100,G7120, G3100 Cable model D work on: LG G7000,G7020,G7030,G7050,G4010,G4011,G4020,G4050,L1 100,L1150 Cable model E work on: LG B1300 Cable model F work on: LG U8110, 8120, 8130 PPShop Team |
Thank You pyroz!
But answer please for my second question--And what must I do , when software detected cable,write "LG cable detected", but not detected phone? Sad "Communication ERROR". WBR Paul. |
which cable and which model of phone ?
br, pyroz |
Member: 7457 Status: Offline Thanks: 1
mine is the same problem
c deducted as e e deducted as c what to do please advice p.s. if it is not dected we can programme ic but it is deducting so if i write write the if it will be solved. ???? |
#12 | |
Member: 65975 Status: Offline Thanks: 25
Best regards. |
Repair of cable C, E :
1. Disassemble black box in the middle of the cable C, E 2. To mark position of cables on PCB (side of cable with connector to the phone) 3. Change positions between C, E cables (side of cable with connector to the phone) 4. Change pinout cable C according to picture : www.ppshop.sk/c.jpg br, PPShop Team pyroz www.ppshop.sk pyroz@ppshop.sk ICQ Number: 85-958-983 |
#14 | |
P.S. I have OLD Blazer Box 1 Year. |
