Member: 85576 Status: Offline Thanks: 0
Best Video Camcoder for nokia 6600
hallo all my friend... can u help me..??
Member: 48893 Status: Offline Thanks: 2
comcoder
USMAN JAVED |
![]() ![]() ![]() ![]() Join Date: Oct 2004
Member: 85082 Status: Offline Thanks: 0
help u ? with what????
Member: 81697 Status: Offline Thanks: 23
philips cam corder pm me
the best is philips camcoder. i have v 1.01 working in my phone. The version 3.7.5 works slow.
I also tried the ETI camcorder Pro, but the quality is the worst. |
Member: 90711 Status: Offline Thanks: 0
Hi
Facing a problem with ETI v3.0 using on 6600 Firmware 5.27 any solution , update or ... Regards Gazan |
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2004
Member: 64382 Status: Offline Sonork: 100.1577130
TRY TO UPDATE TO NEW VERSION IT IS BEST 4 U, IF U DON'T USE philips camcoder V 3.75 U WILL FIND IT HERE :
http://forum.gsmhosting.com/vbb/showthread.php?t=163740 |
#9 | |
But i'll try your file if you've tested on any N6600 and you say it works fine. Another question: Are you able to record videos at 15fps with this settings? audio: on video format: mpeg-4 Quality: Pro Frame Rate: 15fps Frame Size QCIF(176x144) Cause It just let me record at 7,5 fps with this frame size. or at 15fps with SQCIF(128x96) Frame size. żdo you know why this happen? (even saving videos to the phone memory instead mmc memory) |
![]() ![]() ![]() ![]() Join Date: Feb 2003
Member: 21152 Status: Offline Thanks: 0
I have the same problem.15fps on 128x96 and 7.5 at 176x144
