Old 10-12-2004, 16:44   #1
pezus1
Member: 69543
6600 vs pc suite
Does anyone know what the problem can be, if I cant make a backup of my 6600 with pc suite?All the other functions work all right(exp:file transfer) I have already tried to reflash+format user area etc.
I use infrared port.And any other phone can be backed up only mine can not.
Any idea?
Old 10-12-2004, 17:02   #2
steva
steva's Avatar
Member: 4772
which version of pc suite you use?try with latest
regards
Old 10-12-2004, 19:12   #3
Yolly Zubrick
Yolly Zubrick's Avatar
Member: 8396
I think 6600 has a PC Suite designed for it specifically. Are you using the PC Suite for 6600? Since you're using your version of PC Suite with "any other phone", I would presume it's not the PC Suite for 6600. If you want the PC Suite for 6600, you can get it HERE
Old 10-12-2004, 21:04   #4
pezus1
Member: 69543
Ok. I was probobly a little bit misunderstandable.I use pc suite for 6600,and when I wrote "with any other phone" I meant any other 6600!!Are there any new versions of this program??Or what can be wrong?
Old 10-12-2004, 23:16   #5
Yolly Zubrick
Member: 8396
Could it be a firmware issue? If you can backup other 6600 with the same firmware as your fone, it might be a hardware problem.
Old 10-13-2004, 02:14   #6
pezus1
Member: 69543
I thought of the same
Page generated in 0.10161 seconds with 6 queries
